What's wrong with this engine?
Old April 29th 04, 01:50 AM
Fred the Red Shirt
Default What's wrong with this engine?
I was perusing some lists of Ultralight engines and noted that
the Limbach 275 was listed as 20 - 25 hp and 17 lb. I figured
that was a typo, since it was less than half of the weight of
other engines of comporable power--more likely it was 17 hp at
20 - 25 lb, still good stats. But I've seen it listed in three
more places as only 17 lbs or thereabouts including he
http://www.ultralightnews.com/limbach/limbachl275e.htm
Holy crap! How does Limbach do that?
Now, since it develops max power at 7300 rpm you'd need
a 2:1 speed reduction or so to use a 48" prop, effectively,
right? Supposing the speed reducer DOUBLES the weight, it's
still pretty darned impressive. According to what I can find
on the history of Limbach, the design is based on a VW, but
is built from the ground up to be an airplane engine.
So, what is the down side to these engines? Do they cost a
gazillion dollars or blow up at 20 hours or something? There
has to be a downside somewhere.
FF
Old April 29th 04, 01:55 AM
AL
While I cannot speak with absolute authority, a volkswagenesque engine
that needs to run at 7300 rpm would not seem like a high hour engine...
AL
Old April 29th 04, 06:42 AM
Rich
AL wrote in message ...
Other then having horizontally opposed cylinders, I see little
resemblance to a VW. This is a 2 stroke, and the airbox/exaust
doesn't appear to be in the weight. It's gotta be very very loud, and
I'm guessing a muffler would cut into the power.
Rich
Old April 29th 04, 12:04 PM
AL
Hmmm. I'm not familiar with the engine. The OP mentioned it was based on
the VW. My bad assumption.
AL
Rich
Old April 30th 04, 07:49 PM
Fred the Red Shirt
AL
The manufacturer's website says their designs are based on the
VW so I daresay that volkswagenesque was apropos.
Thanks.
FF
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
