Problem updating Oudie2 to 6.0
Old November 16th 14, 11:30 PM posted to rec.aviation.soaring
kirk.stant
Default Problem updating Oudie2 to 6.0
I just tried to update my Oudie2 from 5.2 to 6.0, using Oudie Updater running on Windows7 (which has worked fine in the past). Now my Oudie is stuck on the startup page ("Oudie" with cloud background) and does not respond to either a reset (via the reset button on back) or even to a power off command.
Has anyone else seen this problem?
Kirk
66
Old November 17th 14, 01:40 AM posted to rec.aviation.soaring
kirk.stant
Kirk
66
Update: Got tired of trying to restart the stuck Oudie, so took the dogs for a walk in the snow. On return, Oudie still stuck on the startup page. So tried a combination of pressing the reset button AND the power button at the same time. Presto, it finished starting up, gave me the option of completing the update, and all seems OK now.
My guess is that I started with the battery too low (it was under 20%). Or I just pooched it somehow and unpooched it somehow.
Anyway, all seems fine now.
Kirk
66
Old November 17th 14, 03:40 PM posted to rec.aviation.soaring
Dan Marotta
Not an Oudie, but occasionally my Streak does the same thing. The only
way I've been able to recover it is to remove the back and remove the
battery. It does not have a "reset" button.
Dan Marotta
Kirk
66
Kirk
66
Old November 18th 14, 12:26 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
What is this Oudie Live internet connectivity in 6.0? Does it just connect to the internet through USB via a computer that is connected? I didn't think it had wifi or cellular built in...
Old November 18th 14, 03:08 AM posted to rec.aviation.soaring
Richard[_9_]
dbrunone
The Oudie connects to the PC with a USB cable to the Oudie Updater program. It updates the program, airspace, & vector maps. It will connect to other devices with bluetooth.
Richard
www.craggyaero.com.
www.craggyaero.com
Old November 18th 14, 03:10 AM posted to rec.aviation.soaring
Paul Remde
Default Oudie Live
Hi Bruno,
You can see details on Oudie Live he
http://www.naviter.com/2014/10/oudie...-the-internet/
It is an Android app which is a portal for connecting your Oudie to the
internet through an Android phone. Unfortunately, it is not available for
iPhones.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
__________________________________
"dbrunone" wrote in message ...
dbrunone
Oudie2 connection to LXnav V7 John Docherty[_2_] Soaring 4 October 16th 14 02:27 PM
New Naviter Oudie2 Lite Paul Remde Soaring 0 December 7th 12 03:26 AM
Oudie2 Units in Stock Paul Remde Soaring 0 August 30th 12 03:14 PM
Oudie2's available again in the USA - Upgrades also available Paul Remde Soaring 0 August 20th 12 09:32 PM
Oudie2 units now shipping Paul Remde Soaring 3 April 30th 12 08:51 PM
