Shorter Field Landings?
Old December 8th 14, 08:42 PM posted to rec.aviation.soaring
Graham Drinkell
Default Shorter Field Landings?
I use a 25mm Confor/Dyna Foam type seat cushion, would this help? The
scenario, I suggested- would be to able to stop the a/c quickly!
Old December 8th 14, 08:59 PM posted to rec.aviation.soaring
Luke Szczepaniak
Given your scenario, I would probably do a normal, low energy landing
and force a ground-loop at the last moment to avoid hitting the
obstacle. The foam can absorb energy but won't do anything against hard
objects. As the PIC you will have to make up your own mind ;-)
Luke
Old December 8th 14, 10:15 PM posted to rec.aviation.soaring
Iowa corn fields can be used to REALLY AAAshorten your rollout.
Old December 8th 14, 10:49 PM posted to rec.aviation.soaring
The nightmare scenario landing gear up is hitting a half-buried rock that's hidden in the grass/crop/dirt. I clobbered not one but two such rocks going into a pasture years ago in which another pilot had just landed safely. He didn't see the rocks or the damage they caused until he ran up to my cockpit.
When the wheel/tire hit the first rock, the compression struts in the landing gear failed (as designed; thank you, Gerhard Waibel!), allowing the undamaged wheel/tire to pivot back and up against the bottom of the fuselage where it jammed, keeping the fuselage well above the ground. The *second* rock a few meters later creased the fuselage but did no other damage because I had still had ground clearance. The landing gear absorbed all the shock and was easily repaired by M&H. The damage to my spine if I'd landed wheel up would have been much more severe.
I was sitting on a ridge and had ample time to pick a field and make a pattern and a textbook low-energy approach. I never saw the rocks in the grass.
Chip Bearden
ASW 24 "JB"
U.S.A.
Old December 8th 14, 11:41 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
cockpit.
grass.
IMHO, if stopping short is high on Joe Glider Pilot's priorities (as is, I
presume, doing so without damage to his valued, easily-damaged bod) - and both
these things have always been paramount in all of my off-airport landings
because, after all, I'm about to touch down on a more or less completely
unknown surface, despite my best airborne eyeball inspection - JGP's best bet
is knowing how to make a well-aimed, low-energy approach, flare, and touchdown
followed by the heaviest braking of which pilot/ship are capable without
putting the ship up on its nose. (Of course, you can do that, too, if you wish
and your brake is capable.)
My "hidden rock story" involves a huge, plowed/disc-ed, weed-free field in
eastern Wyoming in which I followed (most of) my above advice, came to a
damage-free stop in about 150 (paced-off) feet...and found I'd missed a
steroidally-enhanced, humongo-sized "loaf of french bread" rock by about 3
horizontal feet. The farmer may well have cussed every time he hit it, since
it was large & heavy enough to bend a disc. It was the only rock I saw in the
half mile I walked to the field's edge.
For the curious, I landed in the middle of the field because it was rolling,
and only my actual flare and touchdown was low energy; I used the extra
approach energy to follow the contour until the energy was no longer needed. A
different (shorter) rolling field may well have warranted a different approach
technique.
YMMV...
Bob W.
Old December 9th 14, 01:05 AM posted to rec.aviation.soaring
Tony[_5_]
Hey Bob remember that piece of re-bar we found just under the nose of the Cherokee in the disced field at Dalhart? That's my favorite prop when telling peoe why you alwyays stop ASAP!
Old December 9th 14, 03:04 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
I remember it NOW, ha ha. I doubt it'd eased from my active memories had it
been MY ship and MY OFL! Murphy exists...
Bob W.
Old December 9th 14, 06:53 AM posted to rec.aviation.soaring
Gear up or gear down?
The question raises an even more important point.
Why is the question even asked on RAS? Should information such as this not be included in the flight training manuals a pilot reads on the way to becoming a licensed pilot?
What other important information is lacking in this pilot's knowledge?
The answer to this particular question is on page 268 of the "Glider Flight Training Manual." Additional important information on this, and other subjects is included on the many other pages.
A small library is a requirement to becoming a safe, proficient pilot.
Tom Knauff
'Shorter field landings? Graham Drinkell Soaring 6 December 8th 14 10:11 PM
(USA only) Managing 911 response to off field landings Jim Beckman[_2_] Soaring 8 August 11th 09 04:23 PM
Variations in soft field landings Maxwell Piloting 42 April 27th 07 05:12 PM
Short vs Soft Field Takeoff and Landings Ol Shy & Bashful Piloting 17 November 17th 06 10:32 PM
Rough Field Landings [email protected] Piloting 38 December 19th 04 01:42 PM
