I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC.
I have never seen a TC. Here are my questions: 1. What does a TC look like? 2. Are copies of the TC available to the public? 3. Is it referenced by the same identifier as the TCDS? I have the same questions about the EASA TC. Looking forward to enlightenment. Thanks. |
On Friday, December 19, 2014 1:11:23 PM UTC-5, Pat Russell wrote:
I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC. I have never seen a TC. Here are my questions: 1. What does a TC look like? 2. Are copies of the TC available to the public? 3. Is it referenced by the same identifier as the TCDS? I have the same questions about the EASA TC. Looking forward to enlightenment. Thanks. There is an FAA Website that has them. Here's an example for Duo Discus. Not all gliders have a Type Certificate in the US (as I'm sure you already know). http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/c65e39afff1d1d778625743b005c49ee/$FILE/G85EU.pdf |
In the US it appears that you are looking for a Form 8110-9, if the following link is accurate: http://www.astech-engineering.com/sy...tcprocess.html I did a quick search and found the blank form, but it wasn't very helpful and I couldn't find a filled in form 8110-9.
-John, Q3 On Friday, December 19, 2014 1:11:23 PM UTC-5, Pat Russell wrote: I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC. I have never seen a TC. Here are my questions: 1. What does a TC look like? 2. Are copies of the TC available to the public? 3. Is it referenced by the same identifier as the TCDS? I have the same questions about the EASA TC. Looking forward to enlightenment. Thanks. |
On Friday, December 19, 2014 1:39:32 PM UTC-5, Papa3 wrote:
On Friday, December 19, 2014 1:11:23 PM UTC-5, Pat Russell wrote: I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC. I have never seen a TC. Here are my questions: 1. What does a TC look like? 2. Are copies of the TC available to the public? 3. Is it referenced by the same identifier as the TCDS? I have the same questions about the EASA TC. Looking forward to enlightenment. Thanks. There is an FAA Website that has them. Here's an example for Duo Discus. Not all gliders have a Type Certificate in the US (as I'm sure you already know). http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/c65e39afff1d1d778625743b005c49ee/$FILE/G85EU.pdf Whoops - this is the main search page where you would start: http://rgl.faa.gov/Regulatory_and_Gu...meset?OpenPage |
I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC. I have never seen a TC. Here are my questions: 1. What does a TC look like? 2. Are copies of the TC available to the public? 3. Is it referenced by the same identifier as the TCDS? I have the same questions about the EASA TC. Looking forward to enlightenment. Thanks. EASA sample here. http://www.windpath.ca/index.php?opt...&id=4&Itemid=4 for the Perkoz. Simple certificate with a signature from your FAA equivalent. |
Thanks, Dan. That's the Canadian equivalent of what I am looking for, and I suspect that the FAA version looks similar. I wonder why they can't be found? Perhaps there's only one copy in a vault in the basement in Oklahoma City.
On Friday, December 26, 2014 9:07:16 AM UTC-5, Pat Russell wrote:
Thanks, Dan. That's the Canadian equivalent of what I am looking for, and I suspect that the FAA version looks similar. I wonder why they can't be found? Perhaps there's only one copy in a vault in the basement in Oklahoma City. I'm curious as to why you are looking for this. UH |
No particular reason. The mind tends to wander this time of year.
| Thread Tools | |
| Display Modes | |
| L13A Type certificate holder | Bruce | Soaring | 7 | August 19th 10 08:01 PM |
| Parachute Required by Type Certificate | [email protected] | Soaring | 1 | April 28th 09 12:15 AM |
| Softie parachute EASA type certificate | bjorn | Soaring | 2 | January 25th 07 07:10 PM |
| Tracking the Elusive Tracing Paper | Veeduber | Home Built | 18 | August 30th 04 01:53 PM |
| C182RG Type Certificate Data Sheets | EDR | Piloting | 6 | July 3rd 04 04:11 AM |
