Oil smoke on startup
Old November 10th 04, 05:26 PM
Gyroplanes
Default Oil smoke on startup
If I remember correctly, my friends Helicom (Safari) used to have a vertically
mounted Lycoming.
If one or more of the oil returns from the rocker covers (valve covers) are
restricted in any way oil will build up in the valve cover and leak in through
the valve to guide clearance.
Lycomings do not have valve seals, so that won't be your problem.
If the oil leak into the cylinder is severe enough, you could experience a
"hydraulic lock" while cranking the engine over.
Oil is not compressible and when the piston meets the slug of oil it usually
results in a bent rod or broken piston.
smoke from engine lescure Rotorcraft 5 November 14th 04 02:56 AM
smoke oil nametab Aerobatics 18 March 25th 04 06:34 PM
Smoke Oil nametab Aerobatics 0 February 11th 04 01:05 AM
STec-30 doesn't pass startup test after I shorted something.... Dave Owning 12 January 18th 04 06:47 AM
Smoke, mirrors and the GBU - 12 Xenia Dragon Military Aviation 14 September 3rd 03 05:09 AM
