Externally mounted GoPros okay?
Old December 30th 14, 07:29 PM posted to rec.aviation.soaring
Jim Lewis[_2_]
Default Externally mounted GoPros okay?
I have seen some wonderful videos made with GoPros stuck on the outside of gliders. Does the FAA have anything to say about the legality of such externally mounted cameras on aircraft certificated as other than experimental?
Old December 30th 14, 08:13 PM posted to rec.aviation.soaring
RL
Yes, in fact they do. This article from AvWeb addresses the issue and includes a link to the official guidance from the FFA.
As quoted from the AvWeb article and verified by the FAA Memorandum, "Basically, the memo says camera mounts aren't major alterations since they don't appreciably change flight characteristics, performance, weight and balance or basic airworthiness. They also don't represent changes to the aircraft's basic type certification, so no STC is necessary."
http://www.avweb.com/blogs/insider/C...-222739-1.html
Bob
Old December 30th 14, 09:29 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Bob
Thanks - I particularly liked the "don't be stupid" part:
The memo further says the FAA doesn't support such attachments and should one come loose, the ever-present FAR 91.13 cudgel--careless or reckless operation--is available for use. And that's as it should be. The act of mounting the camera is not, of itself, careless or reckless; losing it because you didn't do it right might be. Again, case by case.
I made a copy of the FAA memo (link in the article) to take with me to the airport - just in case it comes up.
9B
Old December 30th 14, 10:04 PM posted to rec.aviation.soaring
Jim Lewis[_2_]
Bob
9B
Good information. Thank you.
Seems likely there are places on the outside of a glider that might be unwise to mount a camera. Most are pretty obvious I guess - on a control surface, right in front of a control surface, etc..
Do I feel I know all the unwise places? No. So, I will avoid the temptation to mount a camera on the outside of a glider. YMMV.
Old December 30th 14, 10:52 PM posted to rec.aviation.soaring
Bill T
The GoPro is "large" and should not be in front of a control surface. Depending on the surface, suction cups work great. I would not like to use the tape stuck on mount on a glider finish.
Better use for external use on gliders are small flat,"key fob" sized cameras, low profile, use good double stick foam tape. They cannot normally be remotely controlled, turn it on before launch and forget it.
If you lose one in flight, it's only $10-$20 and ounces falling, not $400 and a half pound falling.
BillT
Anyone ever panel mounted a PCAS MRX? Matt Herron Jr. Soaring 11 April 3rd 09 08:01 PM
Fixing a camera externally Neil Soaring 8 August 9th 07 11:02 PM
Panel mounted GPS on E-Bay. Tri-Pacer Aviation Marketplace 0 May 3rd 07 08:40 PM
Fin Mounted TE Prob vs fuselage mounted TE prob [email protected] Soaring 8 June 4th 05 10:39 PM
Boom mounted O2 cannula Viperdoc Instrument Flight Rules 1 August 21st 03 02:19 PM
