Borgelt B500VE repeater problem
Old January 3rd 15, 05:26 PM posted to rec.aviation.soaring
Fredrik Rutkvist
Default Borgelt B500VE repeater problem
We have a Borgelt B500 in one of our club ships which is giving us a headache! The rear seat repeater is not working properly, at power on it goes to full down and chuggs for a while and then stops and doesn´t respond. The main unit up front is working as it is supposed to so we are currently flying with the repeater disconnected.
We´ve updated the main unit with the last software update but I´m not able to connect the repeater to the computer. Maybe this is not necessary? The manual for the B500 is not giving much information about the repeater and I´ve not been able to find a specific manual for the repeater.
The repeater is connected directly to the main units RJ45 socket marked with a red band which is also the same as used when connecting to a computer, therefore I´ve not been able to connect everything to a computer. Is there supposed to be a splitter or something ong the RJ45 cable to the rear seat? In that case it is missing in our installation.
Does anyone have any ideas on how we can make the repeater work as it is supposed to?
Kind regards
Fredrik Rutkvist
Falun, Sweden
Old January 3rd 15, 06:07 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Have you asked Borgelt about it?
When my B.40 needed an overhaul some years back they were very helpful,
responded fast and did the overhaul promptly and for a very reasonable
cost. Contact details are in the website:
http://www.borgeltinstruments.com/
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 4th 15, 08:26 PM posted to rec.aviation.soaring
Fredrik Rutkvist
Den lördagen den 3:e januari 2015 kl. 19:08:12 UTC+1 skrev Martin Gregorie:
org |
Yep, I sent Mike a mail and got a quick reply after I posted here. Found out I´m missing an adapter between the repeater and the main unit. Hopefully will be here in a couple of weeks, and that it´ll solve my problems.
/Fredrik
ILEC SN10 and repeater FS nimbus[_2_] Soaring 0 June 13th 13 10:57 PM
FS L-nav and repeater [email protected] Soaring 2 April 11th 13 04:41 PM
Wanted - LNav repeater Pete Startup[_2_] Soaring 1 June 10th 12 05:34 PM
BRSS needs L-Nav Vario Repeater PapaFox Soaring 1 August 15th 08 10:53 PM
L-NAV 2 seat repeater needed Ian McPhee Soaring 0 November 1st 07 11:10 AM
