CNvXC to K6BT Cable
Old January 10th 15, 08:15 PM posted to rec.aviation.soaring
Dan Marotta
Default CNvXC to K6BT Cable
Can anybody suggest where I could find a cable to connect my K6BT to my
new CNvXC vario? The cable that went with my 302 had a DB9 male
connector on one end and an 8-pin RJ connector on the other. My K6BT
requires an 8-pin RJ connector and the CNvXC has a 6-pin RJ female.
I'm digging through all my old computer and telephone stuff to see if I
can find a 6-pin connector to build a cable but it'd be easier to simply
buy it.
Dan Marotta
Old January 11th 15, 04:46 AM posted to rec.aviation.soaring
my new CNvXC vario?* The cable that went with my 302 had a DB9 male
connector on one end and an 8-pin RJ connector on the other.* My
K6BT requires an 8-pin RJ connector and the CNvXC has a 6-pin RJ
female.
if I can find a 6-pin connector to build a cable but it'd be easier
to simply buy it.
Dan Marotta
Paul Remde has cables to connect the CNv to the Oudie. I believe the pinout
is the same. I concocted a data cable myself and managed to trip the breaker
when I connected power directly to ground... fortunately nothing fried except
my pride as a geek!
Matt
Request for Developer and Customer Input -- CNvXC Serial Communication Tango Eight Soaring 2 January 7th 15 10:47 PM
CNvXC Serial Port Details Tango Eight Soaring 2 January 6th 15 09:36 PM
Cable AS 6 (302 KB) Steve Woodall Aviation Photos 0 January 11th 10 12:59 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
