Hi all,
I am refurbishing a Komet trailer. The wing fittings have plastic rods to hold the spar end - I have always assumed this is "delrin" but of course when I look into what is available there are a zillion plastic types! What is the best choice? Or does it not really matter as long as it's softer than the spar bushings? Thanks Ben |
On Monday, January 26, 2015 at 5:59:25 AM UTC-5, Ben Coleman wrote:
Hi all, I am refurbishing a Komet trailer. The wing fittings have plastic rods to hold the spar end - I have always assumed this is "delrin" but of course when I look into what is available there are a zillion plastic types! What is the best choice? Or does it not really matter as long as it's softer than the spar bushings? Thanks Ben I does not matter much. I make pins like that out of PVC rod because it is readily available, machines easily and has no negative properties for this application. I just made a set for a Komet. UH |
Speaking of a Komet trailer, I have an LS-3a in a Komet and the factory set up the wing dolly's to use the forward spar pin. This is a very unstable situation and the wing really wants to flop over when running it in or out of the trailer. I set the right wing on the wing dolly using the rear spar pin and the wing skin was touching the dolly (believe this is why they opted to use the forward spar pin). Don't see why I couldn't grind / cut the offending corner off the wing dolly, so that both wings could use the rear spar fittings. The stops would have to be re-set and top capture fittings re-set (checked). Probably get inside the trailer with a flash lite and then ask Pat to close the trailer....................I wouldn't attempt this unless you have a very stable relationship with the wife!
:) JJ |
Thanks.
On Monday, 26 January 2015 22:51:42 UTC+10, wrote: On Monday, January 26, 2015 at 5:59:25 AM UTC-5, Ben Coleman wrote: Hi all, I am refurbishing a Komet trailer. The wing fittings have plastic rods to hold the spar end - I have always assumed this is "delrin" but of course when I look into what is available there are a zillion plastic types! What is the best choice? Or does it not really matter as long as it's softer than the spar bushings? Thanks Ben I does not matter much. I make pins like that out of PVC rod because it is readily available, machines easily and has no negative properties for this application. I just made a set for a Komet. UH |
Our LS4 in a Komet trailer uses the rear spar pin (closest to wing) for the wing dolly.
Bill T |
Comet to Cobra Trailer fittings conversion | Gregg Leslie[_2_] | Soaring | 1 | November 10th 12 07:49 PM |
Comet to Cobra Trailer fittings conversion | Gregg Leslie[_2_] | Soaring | 0 | November 10th 12 12:33 PM |
plastic or metal fenders on the trailer? | chris | Soaring | 14 | December 20th 10 09:51 PM |
Trailer fittings and carpetting | [email protected] | Soaring | 3 | September 4th 09 03:27 AM |
Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 03:21 PM |
