Glider sightseeing flights
Old February 1st 15, 02:53 AM posted to rec.aviation.soaring
Bob Pasker
Default Glider sightseeing flights
Sightseeing flights within 25sm of an airport in airplanes and helicopters are conducted under 91.147 and 119.1(2)
Does anyone know what regulation(s) control sightseeing flights in gliders?
thanks, bob
http://www.law.cornell.edu/cfr/text/14/91.147
http://www.law.cornell.edu/cfr/text/14/119.1
Old November 14th 18, 07:19 PM posted to rec.aviation.soaring
Paul Agnew
How are US clubs dealing with 91.147? Is there an exemption or workaround for this section? Introductory flights?
It came up in conversation recently with my CPA, who also happens to be an FAA Ops Inspector.
PA
Old November 14th 18, 07:31 PM posted to rec.aviation.soaring
Tony[_5_]
91.137 doesn't apply to gliders
Old November 15th 18, 01:47 AM posted to rec.aviation.soaring
Paul Agnew
91.147 - Reference?
Old November 15th 18, 02:06 AM posted to rec.aviation.soaring
Bob,
At first review, 91.147 applies to AIRPLANES and HELICOPTERS. Per FAR Part 1, AIRPLANES, as used with respect to the certification, ratings, privileges, and limitations of airmen, means a broad classification of aircraft.
In other words, AIRPLANES are not GLIDERS, and GLIDERS are not AIRPLANES. However per Part 1, AIRPLANES and GLIDERS are both AIRCRAFT.
Very subtle, but an important point when reading the regulations. These words show up throughout the regulations. Our job is to note the difference.
Raul Boerner
Old November 15th 18, 01:26 PM posted to rec.aviation.soaring
Paul Agnew
I don't follow your logic, Raul, but a reread of the regs revealed 91.147 (a) uses the term "Operator), specifically defines "Operator", and restricts the definition to flights in an airplane or helicopter.
Subsections (b), (c), (d), and (e) clearly refer to "Operator" as defined in (a).
Conclusion, gliders are not subject to this FAR by definition of Operator.
One less problem to solve...
PA
Video Camera/ Recorder to Visually Record Glider Flights From PilotsViewpoint [email protected] Soaring 5 November 17th 07 06:11 PM
Sightseeing Regulations Judah Piloting 4 August 19th 07 01:14 PM
New Charity and Sightseeing Regulations Larry Dighera Piloting 10 May 7th 07 03:21 AM
Gift Cards for Glider Flights - Las Vegas [email protected] Soaring 0 December 16th 06 07:20 PM
FAA to End part 91 Sightseeing flights? Vaughn Rotorcraft 7 November 2nd 03 01:20 AM
