XC soar data issues
Old February 2nd 15, 11:56 PM posted to rec.aviation.soaring
HGXC[_3_]
Default XC soar data issues
I have a dell streak and have downloaded the XC soar software. I am having issues having xc soar recognize the data files like maps airspace and waypoints. I can download these data files directly and I had to use file transfer from my pc.
Any ideas on what I am doing wrong.
Dennis
Old February 3rd 15, 12:06 AM posted to rec.aviation.soaring
Dan Marotta
Your maps, turn points, and special use airspace files have to be loaded
at the top level of the XCSoarData folder which should reside at the
root level of your SD card.
If you ran XCSoar without an SD card, it created an XCSoarData folder in
your internal memory space.
I've found that when you connect your Streak to a PC for file transfer
you have to use "Safely Remove Device" on the PC before turning off USB
file transfer on the Streak. Even rebooting the Streak will not fix
this. You have to turn on USB file transfer, safely remove the streak
as a remote drive, then turn off USB file transfer mode.
Of course, your data files have to be of the proper format and have the
proper file suffixes.
Hope that helps.
Dan
Dennis
Dan Marotta
Old February 3rd 15, 09:46 AM posted to rec.aviation.soaring
Alexander Müller
You can also take out your SD card from your Dell Streak, put it into an SD card adapter and write directly on the card like on a disk drive. Makes it sometimes easier...
Old February 3rd 15, 12:43 PM posted to rec.aviation.soaring
HGXC[_3_]
Dennis
Well we are up and running...thanks all. Now how to connect this to battery for power and my lnav?
Dennis
Old February 3rd 15, 02:56 PM posted to rec.aviation.soaring
Andy Gough[_2_]
Dennis
You need a IOIO board, go here to find out how to build one:
http://www.tophatsoaring.org/IOIO%20...%20pilots.html
or
a blue tooth connection, go here to find suppliers:
http://www.xcsoar.org/hardware/
Old February 3rd 15, 04:20 PM posted to rec.aviation.soaring
Dan Marotta
I originally used the serial port of my CAI 302 for power but I think
that exceed the output capability of the 302 so I installed a car 12v
adaptor with a USB charger and a toggle switch to control charging. I
also used a K6BT for the control/data connection to the 302. The K6BT
is wired directly to my DC bus for its power source. I have a friend who
uses an IOIO and he's happy with that, so it's really up to you.
Depending on your computer/recorder, your log file can be downloaded to
your streak to carry home. Note that the proprietary connector on the
side of the Streak is its weak point and will fail with multiple
connect/disconnect cycles. To get around that, I've permanently
installed the cable in my streak and I download files to my smart phone
(bluetooth).
Now that I've just installed a ClearNav vario, I can simply pull the USB
stick out of the panel and take it home or next door to the FBO to
upload my flight trace.
Dennis
Dennis
Dan Marotta
Old February 3rd 15, 04:56 PM posted to rec.aviation.soaring
HGXC[_2_]
think that exceed the output capability of the 302 so I installed a
car 12v adaptor with a USB charger and a toggle switch to control
charging.* I also used a K6BT for the control/data connection to the
302.* The K6BT is wired directly to my DC bus for its power source.*
I have a friend who uses an IOIO and he's happy with that, so it's
really up to you.
to your streak to carry home.* Note that the proprietary connector
on the side of the Streak is its weak point and will fail with
multiple connect/disconnect cycles.* To get around that, I've
permanently installed the cable in my streak and I download files to
my smart phone (bluetooth).
USB stick out of the panel and take it home or next door to the FBO
to upload my flight trace.
Dennis
Dennis
Dan Marotta
So with a ioio board i could plug it into my cam model 20 gps and get connected and power from there? That's what i plug my compaq pda with glide nav today.
Dennis
Old February 3rd 15, 05:05 PM posted to rec.aviation.soaring
Luke Szczepaniak
charging. I also used a K6BT for the control/data connection to the
302. The K6BT is wired directly to my DC bus for its power source.
really up to you.
to your streak to carry home. Note that the proprietary connector
multiple connect/disconnect cycles. To get around that, I've
Dennis
Dennis
Dan Marotta
Dennis
Should be no problem. If you aren't interested in making your own IOIO
(i've made a few) you can purchase andrport, a neat little ioio based
device that supports two separate NMEA sources.
http://www.glidertools.com/products/androport/
With this you will only need to make cable to connect to your model 20
and provide 12v to the androport which will in turn supply 5v and nmea
data to the android device.. I helped a friend set this up and it went
smoothly.
Luke
Old February 3rd 15, 08:29 PM posted to rec.aviation.soaring
HGXC[_2_]
really up to you.
Dennis
Dennis
Dan Marotta
Dennis
smoothly.
Luke
I can't get that site to come up...says its still in development
Can you send me a different link...I am interested!
Thanks
Dennis
Fat boy wants to soar... toggles mcfarley Soaring 24 March 23rd 10 06:51 PM
XC-Soar [email protected] Soaring 4 January 26th 09 04:06 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
why do you soar? Mark James Boyd Soaring 27 October 21st 03 07:48 PM
