Glider Down - Soaring Mag Feb 2015
Old February 4th 15, 10:05 PM posted to rec.aviation.soaring
son_of_flubber
Default Glider Down - Soaring Mag Feb 2015
The 'Glider Down' article in this month's soaring magazine was great. I hope that the new editor Eric Bick makes this sort of article routine.
Old February 5th 15, 03:24 AM posted to rec.aviation.soaring
BobW
Second! On both fronts.
And Serious Kudos to Jay Campbell for having the mindset to share his accident
with the rest of the U.S. soaring community. I hope he sees fit to learn every
lesson he can draw from the unhappy experience, and opts to continue with the
sport.
Bob W.
Old February 5th 15, 02:48 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Great new look to the mag, but the Libelle article missed the most significant achievement of the old girl. Ray Gimmey won the 1972 open Nationals flying a Libelle!
I too believe we should be reviewing our accidents as George Theylen did in Soaring for many years.
JJ
Old February 5th 15, 04:49 PM posted to rec.aviation.soaring
SoaringXCellence
JJ
There were a bunch of Libelle H301s flying in the '72 nationals. Mine, flown by my father Jack Bamberg, took 3rd.
Old February 6th 15, 03:08 AM posted to rec.aviation.soaring
I also commend Jay for sharing his unfortunate wave experience and turning it into an excellent Teaching Moment.
Old February 6th 15, 03:33 AM posted to rec.aviation.soaring
Mike the Strike
I've known of more than a couple of incidents involving inadvertent opening of spoilers that were not caught by the pilot and led to an accident or nearly so.
I was taught (by a German instructor) always to visually check spoilers when deploying them and again to check they were closed, something I have always done. I also only deploy spoilers when within safe distance of the field and almost never while flying cross-country. I remember a colleague who outlanded when he deployed his spoiler and the handle broke off, leaving them fully open!
Old February 6th 15, 04:39 AM posted to rec.aviation.soaring
Bill D
As long as we are discussion solutions to unintended open spoilers, why not adopt the airplane solution in the form of an annunciator panel on the glare-shield consisting of LED lights? A big red one would indicate unlocked open spoilers and a small green one indicating they are closed and locked. The idea could be extended to the usual red-yellow-green gear warning and even to unlatched canopies and tail dollies still on the tail-boom.
Panels are being packed with an almost unbelievable array of computerized instruments, why not add a row of simple LED lights that might eliminate a few accidents? We now have good batteries and very bright, efficient LED's so why not?
Old February 6th 15, 05:11 AM posted to rec.aviation.soaring
Mike the Strike
Bill: That's a brilliant idea. My Ventus already has an LED light array for flap position on top of the glare-shield - it would be trivial to add similar ones for spoilers and gear.
Old February 6th 15, 09:17 AM posted to rec.aviation.soaring
Jim White[_3_]
Just a thought....would it not be a good idea to fit the flap leds around
the asi in the appropriate positions?
Old February 6th 15, 12:29 PM posted to rec.aviation.soaring
HGXC[_3_]
Hi Mike,
My Ventus also has a LED light array on top of glare shield ...over the years it has developed a short and sometimes doesn't work...do you know a source to replace this panel?
Dennis
ChicagoLand Glider Council Seminar - Feb 21, 2015 Six-Seven Soaring 10 February 17th 15 02:52 PM
ASA 2015 Soaring Season Opener Waveguru Soaring 2 January 31st 15 07:02 PM
Soaring the Appalachians Seminar, 7-8 Feb 2015 [email protected] Soaring 1 January 13th 15 06:49 PM
2015 Region 7 Soaring Contest in Albert Lea, Minnesota Paul Remde Soaring 0 January 13th 15 05:48 PM
Glider rental for the 1st Pan-American Championships in April 2015 Sergio Bassi Soaring 0 October 23rd 14 10:16 PM
