Questions on NiMH Batteries
Old February 25th 15, 11:51 PM posted to rec.aviation.soaring
Dan Marotta
Default Questions on NiMH Batteries
I'm considering replacing the lead-acid tail battery in my LAK-17a with
NiMH batteries. I find D cells rated at 1.2v 10 Ah which would be ideal
to build up a 12v 10 Ah pack. I've already checked fitment in the
sealed battery box using alkaline D cells.
Can anyone tell me if these batteries are actually 1.2v. If so, I'd
need to use 11 or 12 of them to get the voltage I want.
Dan Marotta
Old February 25th 15, 11:58 PM posted to rec.aviation.soaring
Andrzej Kobus
with NiMH batteries.* I find D cells rated at 1.2v 10 Ah which would
be ideal to build up a 12v 10 Ah pack.* I've already checked fitment
in the sealed battery box using alkaline D cells.
Can anyone tell me if these batteries are actually 1.2v.* If so, I'd
Dan Marotta
Dan, NiMH are a really bad choice. I know someone whose battery in a glider got really hot to the point of melting fiber glass. These batteries were put in by a glider manufacturer and properly sized.
If you want more information contact me directly.
Old February 26th 15, 12:19 AM posted to rec.aviation.soaring
Dan Marotta
PM sent.
with NiMH batteries. I find D cells rated at 1.2v 10 Ah which would
be ideal to build up a 12v 10 Ah pack. I've already checked fitment
Dan Marotta
Dan Marotta
Old February 26th 15, 01:56 AM posted to rec.aviation.soaring
Darryl Ramm
Dan Marotta
Bad choice: compared to other options the have poor energy density, poor charge performance, can represent a higher fire hazard, require a specific type charger. You should not try to fast charge a NiMh pack in an enclosed space, especially without a thermal monitoring charger/cutoff. There is just much better battery technology available. Especially LiFePO2 batteries.
I am also aware of a glider NiMh battery with serious thermal damage caused by improper charging/insufficient manufacturer warnings, etc.
Old February 26th 15, 05:44 AM posted to rec.aviation.soaring
bumper[_4_]
Darryl,
Did you mean LiFePO4?
Likewise, familiar with the glider that had issues with NiMH batteries. Besides the NiMH relatively high self-discharge rate, when using multiple batteries is keeping things balanced. This is exacerbated if the batteries are not all in the same location, as differing lengths and thus resistance of interconnect wire is enough to pretty much insure things will not go well, with some cells overcharging, deep discharging, or even reversing cell polarity.
bumper
Old February 26th 15, 05:55 AM posted to rec.aviation.soaring
Darryl Ramm
Darryl,
bumper
Uh yes, LiFePO4. But if anybody can find a LiFePO2 battery call me.
Old February 26th 15, 03:16 PM posted to rec.aviation.soaring
Pierre Vav
Hi,
I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17.
They have the same format as alkaline D cells.
I use a RC charger that automatically detects the right number of elements.
At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v).
As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok.
I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4.
also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig.
Old February 26th 15, 05:03 PM posted to rec.aviation.soaring
Papa3[_2_]
bumper
On Thursday, February 26, 2015 at 12:44:52 AM UTC-5, bumper wrote:
Darryl,
PO2/PO4, 220/221, "whatever it takes"
www.youtube.com/watch?v=iX3kxAA2L4Q
Old February 26th 15, 05:13 PM posted to rec.aviation.soaring
Dan Marotta
Thanks to all.
It looks like NiMH batteries are out of the question for me. I have a
10 Ah LiFePO4 drop-in replacement as my main battery and am very happy
with its performance. I'm looking for LiFePO4 cells (and BMS) for
protection that can fit in my tail battery box. The dimensions of the
drop-in box a
Length = 58 cm
Width = 3.5 cm
Height = 6.5 cm
No luck so far, but I'm continuing the search. I could also build up a
pack for a separate box which I've installed behind the seat back. Its
dimensions a
Length = 36 cm
Width = 4.8 cm
Height = 10.8 cm
Any suggestions would be most welcome. I've been searching the net, but
nothing yet satisfies my specific needs.
Dan
On 2/26/2015 8:16 AM, Pierre Vav wrote:
Hi,
Dan Marotta
Old February 26th 15, 05:57 PM posted to rec.aviation.soaring
Pierre Vav
If you find something compliant, please keep us informed.
NIMH batteries - slightly OT Martin Gregorie[_4_] Soaring 13 April 15th 09 03:17 AM
NIMH Batteries K M Soaring 23 December 9th 08 09:27 PM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
C & D NiMH Best Deal Larry Home Built 6 October 1st 04 01:41 PM
AA NiMH Best Deal Jim Weir Home Built 27 September 29th 04 08:39 PM
