MicroAir760 radio
Old March 2nd 15, 01:08 PM posted to rec.aviation.soaring
Colin Roney[_2_]
Default MicroAir760 radio
Hi. Anyone prepared to undead a dead MicroAir 760 radio for me. I think it
is the internal fuse but I may be wrong. Based East Anglia.
Old March 2nd 15, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
According to Microair's website, it looks like France is your nearest
service center.
http://www.ipco-instruments.com/
Dan Marotta
Old March 3rd 15, 03:33 PM posted to rec.aviation.soaring
US Service address below.
Sent mine back in last year and he did a great job.
Rick Lord
MicroairUSA Service Centre
2711 Legion Rd. # 8564
Erie, PA 16506-3100 USA
Phone: 814-882-2855
Kevin
92
Old March 3rd 15, 05:37 PM posted to rec.aviation.soaring
Rick Lord
Phone: 814-882-2855
Kevin
92
Had mine worked on last year also. Does excellent work
Old March 5th 15, 02:40 AM posted to rec.aviation.soaring
WB
Plugged our Microair into a battery the wrong way 'round, did we? Been there, done that at least three times (yes, I am that stupid). The good news is that each time, it only cooked the picofuse and did no other damage.
The internal fuse (picofuse) is very easy to fix yourself. First you take out all 12,000 screws that hold the cover on. When you have the cover off, look for the picofuse in the top right rear corner of the radio (if I remember correctly). It looks a lot like a resistor. It will be obviously burned if it is blown. It is a very common part, so your local electronic parts dealer should have them in stock. Clip the picofuse off by cutting the legs near the body of the fuse. This will make soldering on the new fuse much easier. Solder the new fuse to the legs of the old fuse, bending it over a bit to make sure it is not sticking up in the way of the cover. Replace the cover with the 12,000 screws. Swing a dead cat over it, say "Arise" and your radio should live again.
ics plus nav/com radio new pat[_3_] Aviation Marketplace 4 September 17th 10 07:38 PM
King Johnny Calls In to Talk Radio in America - These calls are just a small random grouping of call-ins I've done in these last several weeks in America - King Johnny Calls In to Talk Radio in America Ian B MacLure Naval Aviation 0 April 14th 09 05:28 AM
Old Radio Clint Soaring 0 January 17th 06 11:01 AM
What was he/she doing? No radio, NW_PILOT Owning 18 January 18th 05 10:37 PM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 12:02 AM
