Anyone know why the FlarmNet download links have been temporarily removed, and when they will be restored?
BTW, this is an excellent time to REGISTER YOUR AIRCRAFT if you own a Flarm and have not yet done so. Follow the link he http://www.flarmnet.org/index.php/en/register-now Thanks, Matt H |
On another note with flarmnet, when you register you need
to enter either your Flarm ID number OR your Hexadecimal from your aircraft. If you have a transponder you need to enter the Hexadecimal. For those with out transponder which do you enter? I think if you have no transponder you need to enter the Flarm ID instead of the Hexadecimal, but I have heard arguments for both sides and it appears a lot of pilots are unsure, would be nice if we all had this info entered correctly it is nice to see the glider ID of whoever is showing up on your Flarm screen. |
Hi Joe,
I recommend entering the Mode S ID - regardless of whether you have a transponder installed. I can't think of any reason not to. Every aircraft in the U.S. has a Mode S ID assigned. You can find them using the links in my PowerFLARM Tips document and at the top of my PowerFLARM page. http://www.cumulus-soaring.com/flarm.htm http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________________ "joesimmers" wrote in message ... On another note with flarmnet, when you register you need to enter either your Flarm ID number OR your Hexadecimal from your aircraft. If you have a transponder you need to enter the Hexadecimal. For those with out transponder which do you enter? I think if you have no transponder you need to enter the Flarm ID instead of the Hexadecimal, but I have heard arguments for both sides and it appears a lot of pilots are unsure, would be nice if we all had this info entered correctly it is nice to see the glider ID of whoever is showing up on your Flarm screen. |
On Friday, March 6, 2015 at 12:47:12 AM UTC-5, Matt Herron Jr. wrote:
Anyone know why the FlarmNet download links have been temporarily removed, and when they will be restored? BTW, this is an excellent time to REGISTER YOUR AIRCRAFT if you own a Flarm and have not yet done so. Follow the link he http://www.flarmnet.org/index.php/en/register-now Thanks, Matt H I am not sure I see the point in registering if no one can download and use the file. As it stands now, there is no FlarmNet file available to anyone. |
I am not sure I see the point in registering if no one can download and use the file. As it stands now, there is no FlarmNet file available to anyone. I just downloaded flarmnet data version 002ce9. 2D |
Am 06.03.2015 um 06:46 schrieb Matt Herron Jr.:
Anyone know why the FlarmNet download links have been temporarily removed, and when they will be restored? BTW, this is an excellent time to REGISTER YOUR AIRCRAFT if you own a Flarm and have not yet done so. Follow the link he http://www.flarmnet.org/index.php/en/register-now Thanks, Matt H There has been a vivid discussion in Germany about the free use of the Flarmnet data by third party applications (OGN tracking service). As a result of this discussion, Flarmnet has temporarily withdrawn the data formats that have no proper encryption of the data. The BFN format still contains all data and will work with your Butterfly Display, but not with LX, Naviter, XCSoar. -- Peter Scholz ASW24 JE |
On Friday, March 6, 2015 at 10:44:21 AM UTC-5, Peter Scholz wrote:
Am 06.03.2015 um 06:46 schrieb Matt Herron Jr.: Anyone know why the FlarmNet download links have been temporarily removed, and when they will be restored? BTW, this is an excellent time to REGISTER YOUR AIRCRAFT if you own a Flarm and have not yet done so. Follow the link he http://www.flarmnet.org/index.php/en/register-now Thanks, Matt H There has been a vivid discussion in Germany about the free use of the Flarmnet data by third party applications (OGN tracking service). As a result of this discussion, Flarmnet has temporarily withdrawn the data formats that have no proper encryption of the data. The BFN format still contains all data and will work with your Butterfly Display, but not with LX, Naviter, XCSoar. -- Peter Scholz ASW24 JE Ah. I downloaded the .bfn file for my Butterfly. |
| Thread Tools | |
| Display Modes | |
| (USA) FlarmNet usage | 2NO | Soaring | 15 | April 30th 13 12:58 PM |
| PF Portable and Flarmnet | Andy[_1_] | Soaring | 0 | October 5th 12 03:55 PM |
| FLARMnet file update | Andy[_1_] | Soaring | 1 | September 25th 12 07:59 PM |
| FlarmNet | Brad[_2_] | Soaring | 6 | August 26th 12 07:35 PM |
| DAFIF database to be removed from public domain | André Somers | Soaring | 2 | January 14th 05 05:10 PM |
