300lb (130kg) pilot
Old March 7th 15, 04:33 AM posted to rec.aviation.soaring
Default 300lb (130kg) pilot
Hello everybody, I'm a instrument rated private pilot with 120 hours TT, all single engine piston A/C.
I've been meaning to get a glider rating for a long time, mainly because I want to learn soaring and possibly do some light aerobatics on the cheap.
However I've been steered away several times due to the lack of options of gliders that would accomodate my size, height and weight.
I'm 300lbs, 6'3", tall, fat, big, with VERY wide shoulders.
I did contact most soaring schools and clubs here in the SE (FL,AL,GA). My options were limited to Schweizer's 2-33 / 32 if I'm not mistaken.
One of the clubs agreed to take me up, but if I recall correctly they wouldn't have an examiner light enough to stay within W&B for the checkride.
Assuming I manage to get the rating somehow in one of the Schweizer's, what would be my options if I were in the market for a single seat sailplane with respectable performance for light aerobatics ?
Again, I'm 300lbs, 6'3", tall, fat, big, with VERY wide shoulders.
Budget is 20K.
On a side note, how feasible would be for 'this' pilot to get a towing job ?
Fresh CSEL 250 hours
Multi, Instrument, Glider, AG ratings
Tailwheel and 20 hours of pawnee.
If you didn't get the picture yet;
I'd pretty much like to soar, loop, spin and roll for fun while sharpening stick and rudder skills without an engine to worry about (cheap), and build tailwheel time while applying for spray jobs.
Old March 7th 15, 06:03 AM posted to rec.aviation.soaring
Bill T
Pretty much the only glider I can think you could possibly fly is the Schweizer 2-32. Not a 2-33.
I do not think there are any current production gliders that can handle 300# in a seat.
Most European gliders are certified to 110kg (242 lb US) per seat and a max all up weight of non flying parts that your 300# would max.
Not only is max GW an issue, but also CG.
Even if you would violate the Max wt per seat issue, our Grob 103 max useful load is 400#, so your instructor would have to be below 100#.
As for the Pawnee, I'll have to check my plane, but I think our Max pilot weight is below 300# for CG limit.
BillT
Old March 7th 15, 06:05 AM posted to rec.aviation.soaring
Bill T
300 # is 136kg
Old March 7th 15, 06:07 AM posted to rec.aviation.soaring
bumper[_4_]
Glider with "respectable performance", rated for aerobatics, 300 lb pilot weight, and cheap? This is one of those pick any two moments :x)
300 lbs weight will rule out most single seat composite gliders I'm aware of, as most have an upper seat limit of 242 lbs, simply fitting in will be another issue, though broadness in hips or shoulders can further limit choices.
Compared to renting powered aircraft, renting gliders can be significantly less expensive. But as far as purchasing, I think you are not going to get into an aerobatics capable, decent performing glider, or powered aircraft, for $20K. Maybe a partnership or club with a Citabria and go for powered aerobatics?
"I'd pretty much like to soar, loop, spin and roll for fun while sharpening stick and rudder skills without an engine to worry about (cheap) . . ."
It won't be easy to find "cheap", but as to powered aerobatics, I wouldn't fret about the engine - - if it quits, you'll have the glider you wanted in the first place. Albeit, not such a high performance one.
good luck
bumper
Old March 7th 15, 08:39 AM posted to rec.aviation.soaring
Bruce Hoult
I'm 5'11" and about 280 - 285 lb. I'm a (junior) instructor at my club, taking members of the public for their first lesson, and students close to or just after solo standard but not yet cross country rated for soaring flights.
As with any aircraft, a glider's published maximum limits and performance numbers don't stand alone, but form an interrelated web.
Many light aircraft have two or more sets of figures published (for example normal or utility or aerobatic category) with different maximum weights, maximum G loadings, C of G position, takeoff roll, climb rate etc.
Gliders don't usually have that on paper, but in reality similar tradeoffs apply.
The first thing is that 110 kg (242 lb) seat loading limit. That is calculated so that seat belts and mounts will survive a 40 G crash. If you're not planning to crash, or if you'll keep the crashes down to 20 or 30 G then you can ignore that. Some owners may decide they don't want to ignore it ("if you crash our insurance may be declined"), others are more relaxed. Technically, if it was not a contributing factor to *causing* the crash (and it won't be, as such), then there should be no grounds to decline a claim. I've found that Australian clubs are sticklers for this (and thus I haven't been able to fly there) while NZ clubs are relaxed about it.
The second thing is all up weight and weight of the non-flying parts. These are structural strength things. Our DG1000 two-seat trainers are rated for 7 G aerobatics. If you're 5% or 10% (20 or 40 kg) over the maximum weight of the non-flying parts then you're going to be ok if you de-rate the maximum G. Personally, I have no desire to do anything that involves more than 3 G, or maybe 4 very briefly. In soaring glider flying you don't go over 2, other than from gusts. It's also a good idea to de-rate the Vne.
The third thing is Center of Gravity. That's the important one. Going too far rearwards (light pilots) is a killer. Don't do that. Going too far forwards may be slightly bad for performance, as you tend to constantly need more up elevator than normal, however it is not unsafe, as long as you are prepared to use (very slightly) higher takeoff and landing speeds. If you have trouble getting it to rotate and lift off on takeoff then abort. When in free flight, find the minimum possible flying speed (you may not be able to get it to actually stall), and use that as the "stall speed" for approach speed planning ("stall" speed plus 10 knots plus half the wind speed).
In a two seater, the back seat is often much more roomy, and always has a smaller effect on the C of G. Unless I'm flying with someone in the front seat who is themselves over 90 kg (200 lb), I have the DG1000 at pretty much the ideal C of G position (with the tail weight compartment full).
In a small piston plane, overloading is dangerous primarily because of the longer takeoff run (I think T/O distance proportional to weight to the power of 2.5?) and the reduced climb rate. Actually breaking the things in mid-air is not usually the problem.
With a glider launched by the typical powerful Pawnee or winch that is simply not going to be an issue.
Old March 7th 15, 03:58 PM posted to rec.aviation.soaring
Bill T
Interesting comments from Bruce. Just be aware that any time you exceed the numbers in the aircraft manual, YOU are now a test pilot and risk taker.
Providing rides to the general (unknowing) public, and anything happens causing injury, an unlatched canopy, hard landing, rope break into the trees or rocks, and you have just introduced yourself and your club to a world of liability issues. Same goes with students, who are relying on the experience and knowledge of their instructors.
I agree with you logic on flying to reduced G loads or Vne, but I do not agree with the practice.
This will not happen in my club. I am at 210# and know the max weight of any student or passenger I can take in any glider I fly.
We live in a very sue happy environment now. Why ask for a problem you cannot defend.
BillT
Old March 7th 15, 04:20 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Discussed before at https://groups.google.com/forum/#!to...ng/fRDFby79mzA
Old March 7th 15, 06:30 PM posted to rec.aviation.soaring
son_of_flubber
My intention is to be polite and kind... being a glider pilot can be a powerful motivation to stay fit and keep the weight off.
You probably cannot have your cake and eat it.
Old March 8th 15, 01:18 AM posted to rec.aviation.soaring
SoaringXCellence
One of the two place ships that can do what you ask is a Brasov Lark (the -28, I think). When we had it flying (more later) we could have a 200 pound instructor and 300 pound front seat occupant and stay in all limits.
BUT they are mostly at the end of the manufacturers life limits. Ours timed out (by calendar)with only about 1200 hours on the airframe.
If you can find a newer one it might be a good choice.
Old March 8th 15, 02:47 AM posted to rec.aviation.soaring
Bill T
Based on when most of the Larks were built, I would think that 90% of them have reached the calendar life limit.
BillT
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
Get trained in Commercial Pilot, Private Pilot, Sports Pilot andmuch, much more. [email protected] Products 0 November 25th 08 02:53 PM
Get trained in Commercial Pilot, Private Pilot, Sports Pilot andmuch, much more. [email protected] Simulators 0 November 25th 08 02:52 PM
FA: Cessna Private Pilot and Instrument Pilot Complete Training Kits Wei-En Tan Aviation Marketplace 1 May 30th 04 07:38 PM
Beach officials charge Navy pilot with bigamy, By MATTHEW DOLAN , The Virginian-Pilot Otis Willie Naval Aviation 0 April 7th 04 08:14 PM
