Wheel brake cable?
Old March 13th 15, 04:04 AM posted to rec.aviation.soaring
Movses
Default Wheel brake cable?
The brake cable on my ship needs to be replaced - stretched, adjustment barrel is already at the end of the range, etc.
The diameter of the cable is 2mm, and it seems like they don't use 2mm cables on bicycles anymore. 1.6mm brake cables are readily available, but I'm not sure if they're adequate.
Where do I get 2mm cables?
-Movses
PW-5 Brake Cable Replacement [email protected] Soaring 1 July 31st 14 07:41 PM
Duo Discus Wheel Brake Karl Striedieck[_2_] Soaring 1 January 24th 12 10:49 PM
SZD-55 Wheel Brake David Pye[_2_] Soaring 4 September 19th 07 03:10 AM
SZD-55 Wheel Brake David Pye[_2_] Soaring 0 September 18th 07 06:01 PM
Pilatus B-4 Wheel Brake Cable thermalrider Soaring 2 January 28th 06 11:12 PM
