Blackburn Beverley In Action
Old March 25th 15, 11:17 AM posted to alt.binaries.pictures.aviation
Ri©ardo
Default Blackburn Beverley In Action
Here's a Beverley in action.
This aircraft had a double decker type fuselage, the crew being upstairs
with accommodation extending into the tail boom This, as well the side
doors, could be used for paratrooping purposes but luckily, as it
entailed jumping into a hole in the floor of the boom, I managed to
avoid that pleasure.
I did notice on one drop, where I got the number one position to be
first out of the door, that the wheels were spinning pretty fast with
the slipstream.
Its aerodynamics preclude using this aircraft as a glider, and on
another occasion, this time with me being the last in a stick of twenty
on the starboard side, we were flying into a closed valley, at between
600 to 800 feet which was our usual dropping height, with the land
rising in front of us.
We were stood at "action stations" with about a hundredweight of kit
attached to our bodies. The red light was on as we waited for the "green
on GO" order when all four engines stopped. As the parachute dropping
speed of this beast was only about ten knots above stalling speed this
could have been a very difficult situation and, indeed the aircraft
immediately started to yaw.
After an hour or so of low level flight with several other aircraft (low
enough for livestock to stampede as we went over) in a non-pressurised
aircraft, the lack of noise was stunning. You could here the wind
whistling over the aircraft.
The RAF dispatcher was up the steps to the crew cabin in seconds and
almost immediately the four engines coughed and then roared back into life.
Full power, a hasty climb, then a circuit and return to the original
course and off we went.
We later learnt that someone in the crew had failed to switch over to
the reserve fuel tanks, an oversight that could have had very annoying
consequences.
Interesting times! I never did tell my wife about that one.
Ri©ardo
Moving Things In Still Pictures
Name:	000 Blackburn Beverley.jpg
Old March 25th 15, 04:29 PM posted to alt.binaries.pictures.aviation
john szalay
=?UTF-8?B?UmnCqWFyZG8=?= wrote in
upstairs with accommodation extending into the tail boom This, as well
the side doors, could be used for paratrooping purposes but luckily,
as it entailed jumping into a hole in the floor of the boom, I managed
to avoid that pleasure.
Ri©ardo
I think many old paras, can relate horror stories about their days
in the service.
the C-124 Globemaster also had an upper deck, and it was a pain
if you were on the upper deck and had to walk down the ladder to get in
line to the jump door.
I had two horrible flights on "Old Shaky" out of the several we flew on
them, one was on a HOT August day when the thermals were really nasty
we bounced all over the sky, flight was so rough everyone was airsick, I
was first in the door on the green light, I was so ready to get off the
plane, I could not jump I just fell out the door, , when I got on the
ground, I just pulled the chute over me and lay there, the medics drove
up to check me, I just said go away and let me die here..
Barf..............
the other flight was a night jump, they opened the jump door, we stood up
and hooked up, one idiot who was close to the door, didn,t keep his hand
over the D-ring on his reserve, & bumped someone , the reserve dropped
out and the wind from the open door whipped the chute and then jumper out
the door, miles before the DZ. landed in the trees , they spent most
of the night looking for him.. he lived, but he suffered bad back
injuries from being jerked out the door. was on light duty for months..
UK2 WZ889 Blackburn Beverley.jpg Joseph Testagrose Aviation Photos 0 March 24th 15 01:51 PM
Planes - File 10 of 65 - Blackburn Beverley C.1.jpg (1/1) Troy24 Aviation Photos 0 April 27th 08 01:19 AM
Ugly Airplanes - Blackburn Beverley.jpg (1/1) Mitchell Holman Aviation Photos 2 February 27th 08 02:38 AM
