New Glider Static / Pitot / TE Checkout
Old April 10th 15, 05:33 PM posted to rec.aviation.soaring
MNLou
Default New Glider Static / Pitot / TE Checkout
To move a previous discussion to a new topic. (And to mirror a comment by JSC)
If one is getting a new / used glider and wants to check out the Static / Pitot / TE systems on the ground, what is a recommended procedure?
TIA -
Lou
Old April 10th 15, 07:01 PM posted to rec.aviation.soaring
Here is an excellent how to by Mike Borgelt.
http://www.borgeltinstruments.com/Leaks.pdf
Randy
Old April 10th 15, 07:07 PM posted to rec.aviation.soaring
Andrew[_14_]
I found this article from Borgelt Instruments useful.
http://www.borgeltinstruments.com/Leaks.html
For me, I had a leak in a tiny little calibration tube used with a Scheumann compensator. The tubing literally disintegrated when I touched it. It was rarely checked because the Scheumann is installed behind the gear with an inspection panel access.
The article pointed me to Permatex Aviation Form-A-Gasket No.3 Non Hardening sealing compound which was especially useful for the Scheumann tube replacement since the tubing I had to use wasn't the ideal fit.
Also, found a leak in a vario capacity flask...
And watch out for the all-in-one tubing connectors (or whatever they're called), the little o-ring in those tend to deteriorate. These are identified by multiple tubes leading into a threaded cylinder shaped connector. T-connectors are preferred over these...
TIA -
Lou
Old April 11th 15, 06:48 AM posted to rec.aviation.soaring
TIA -
Lou
Lou,
Check out a Soaring Mag. article July 2005 by Lee Kuhle, "How's Your Plumbing"
You can probably find the article archived on the SSA Web page.
From memory, Mr. Kuhlke has you use Syringes of various capacities and the ASI to check the entire system for leaks.
Regards,
David Walsh
Pitot/Static/Transponder Problem Kyle Boatright Home Built 26 August 18th 07 08:31 PM
Pitot Static 411 413 followup post A Lieberman Owning 12 June 18th 05 04:00 PM
Sharing static and pitot line Istvan Csonka Soaring 13 March 12th 05 03:00 AM
pitot/static location Ray Toews Home Built 2 December 30th 03 12:52 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
