Flarm Update - change to config file required?
Old April 18th 15, 01:24 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Flarm Update - change to config file required?
Updated to V6 last week. Didn't see anything in the release notes or on the Flarm website about any requirements to create a new config file. Anyone else know differently?
P3
Old April 18th 15, 03:42 PM posted to rec.aviation.soaring
P3
Yeah, it's been covered in some of the update threads. They (Flarm) have a new config generator you need.
Old April 18th 15, 08:56 PM posted to rec.aviation.soaring
Tango Eight
P3
The new config tool is here https://flarm.com/support/tools-software/
It has a few new commands, but it looks like our old config files should be forward compatible.
-Evan Ludeman / T8
Old April 27th 15, 07:39 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
P3
I updated my Core to 6.xx and went to R5N, Perry, without testing. :-( The Flarm and GPS did not speak to my SN10 anymore. It did record the flight, and the range analyzer showed I was receiving other units well.
Today, I loaded a new Config file made with the config tool. I used "71" for the NMEAOUT1 and 2, instead of the previous "61". It all works again! Baud rate both 1 and 2 is "2" (19,200). Now it works!
Bottom line--yes I needed new config file.
Old April 27th 15, 11:13 PM posted to rec.aviation.soaring
Papa3[_2_]
I went ahead and flew with the new V6 software but the same old config file.. According to others they saw me just fine and vice-versa, so I'm tending to agree with Evan. Haven't had a chance to create a new file and do a diff, but the old config file seems to work. Anyone know for sure what changed in the config files?
P3
-Evan Ludeman / T8
Old April 27th 15, 11:35 PM posted to rec.aviation.soaring
Tango Eight
On Monday, April 27, 2015 at 6:13:26 PM UTC-4, Papa3 wrote:
I went ahead and flew with the new V6 software but the same old config file. According to others they saw me just fine and vice-versa, so I'm tending to agree with Evan. Haven't had a chance to create a new file and do a diff, but the old config file seems to work. Anyone know for sure what changed in the config files?
P3
-Evan Ludeman / T8
It would be kinda nice if they published the new dataport spec... then we'd know for sure....
-Evan
Old April 28th 15, 11:01 AM posted to rec.aviation.soaring
P3
One more fact--the USB thumb drive I used to load v6.xx did not have a config.file on it-I assumed that the flarm was already "configd". When I put the new config file on the thumb drive and inserted it, turned on the flarm and waited for the green light. Next chance, I'll config with the old "6" protocol and see if that works. I used "7" at Paul Remde's suggestion from his website.
New FlarmView Flarm Config Menu? [email protected] Soaring 0 February 27th 14 05:06 PM
Flarm with Firmware 1.20 update Robert Fidler[_3_] Soaring 49 January 31st 12 03:40 PM
Red Box FLARM update question Martin Gregorie[_5_] Soaring 1 June 11th 11 10:13 PM
FLARM UPDATE? Stephen Michalik Soaring 6 March 20th 11 04:24 PM
Help required: Document change control of JAR's [email protected] General Aviation 0 September 12th 05 02:48 PM
