Lak 12 Factory trailer brakes overhaul?
Old April 23rd 15, 11:10 AM posted to rec.aviation.soaring
Colin Roney
Default Lak 12 Factory trailer brakes overhaul?
Anyone had any experience of overhauling the brakes/braking system on
original LAK 12 factory supplied trailer - Difficult/Easy?
Old April 24th 15, 06:15 PM posted to rec.aviation.soaring
son_of_flubber
No LAK experience, but consider swapping a complete new assembly onto the axle. That is very easy and you only have one part number to match. On ALCO assemblies, the part number is stamped on inboard side of the backing plate. Crawl under the trailer with a bright flashlight and a piece of sandpaper.
Old April 25th 15, 06:39 AM posted to rec.aviation.soaring
Frank Whiteley
There is a LAK12 Yahoogroup. You might ask the question there. I know that some have replaced the axle. If the drums are good, you can have the shoes re-surfaced. If you are speaking of the large fiberglass trailer, I suspect that will be your likely option. The surge linkage is mechanical. The surge trailer tongue may be serviceable, but if kept greased, would not see an issue.
Frank Whiteley
For sale: LX5000 fresh from factory overhaul Eric Munk Soaring 0 April 23rd 13 08:50 AM
Electric Trailer Brakes, (Revisited) sisu1a Soaring 14 June 9th 08 07:32 PM
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? Mike Spera Owning 6 December 13th 04 01:13 AM
Cobra Trailer brakes R Barry Soaring 22 July 19th 04 04:51 PM
Trailer brakes Bert Willing Soaring 1 October 31st 03 07:55 AM
