FAA Wants To Cancel 736 NDB, VOR/DME Approaches
Old May 4th 15, 01:26 AM posted to rec.aviation.piloting
Bug Dout
Default FAA Wants To Cancel 736 NDB, VOR/DME Approaches
Larry Dighera writes:
The FAA has published a list of 736 NDB and VOR/DME instrument
approaches (PDF:
Well, the NDB stations should disappear. VOR, no opinion, but they all
gotta go at some point.
As for solar flares, etc. OK, I'll take your word for it. Perhaps, with
advances in semiconductor sensors, relatively cheap inertial
navigation can be constanly online, so a GPS outage on final (and
elsewhere) need not be a catastrophe.
The agency says it can't afford to keep expanding satellite-based services
while maintaining the current ground-based infrastructure.
Even as it expands its ground stations: the many ADSB stations.
Never interrupt your enemy when he is making a mistake.
~ Napoleon
This email has been checked for viruses by Avast antivirus software.
http://www.avast.com
Old May 4th 15, 10:59 AM posted to rec.aviation.piloting
Larry Dighera
So, it's good enough, in the future NextGen satellite-based ATC system, to
expect that "perhaps" airline passengers will reach their destinations safely?
:-( It seems more like planning to fail in order to generate revenue for big
business, to me.
The cost-saving incentive of NextGen ATC is flawed, aircraft position will
become dependent on what the aircraft reports rather than empirical evidence of
its position, ATC will be wrest from government control, and in-flight safety
will be reduced, but that's okay, because Boeing will make a butt-load of cash
in user-fees. :-(
http://www.nasa.gov/topics/solarsystem/features/spaceweather_hazard_prt.htm
"Without preventive actions or plans, the trend of increased dependency on
modern space-weather sensitive assets could make society more vulnerable in the
future."
--Richard Fisher, director of the Heliophysics division at NASA Headquarters
in Washington, 2008
Old May 7th 15, 02:34 AM posted to rec.aviation.piloting
Bug Dout
in user-fees. :-(
The big problem with current primary radar and Mode C transponders, as I
understand, is they're accurate to only within a mile. Not good enough
to squeeze anticipated future traffic into the same airspace. ADSB is
not designed to save money over the current Primary+Mode C system. It's
designed to prevent anticipated future congestion.
I think you're too pessimistic. The FAA is somewhat incompetent for
sure, but there's no conspiracy or Machivellian scheme for GA user
fees, grabbing control or giving up all control, etc.
It's not what you don't know that hurts you. It's what you know that
just isn't so.
~ Satchel Paige
Old May 7th 15, 09:48 PM posted to rec.aviation.piloting
Larry Dighera
in user-fees. :-(
That's hardly a cogent argument to compromise air safety by exclusively
implementing a satellite-based ATC system that is vulnerable to solar CMEs.
ADSB is
I have no delusions that anything connected with NextGen ATC will save money
despite the argument industry initially used to persuade FAA to consider a
satellite-based ATC system. I'm just disappointed that I haven't heard
anything from industry nor FAA that addresses the vulnerabilities of
satellite-based ATC.
You erroneously infer pessimism where I implied safety concerns, redundancy and
conservatism. Let me try again:
1. What will the PIC do about the reduced separation resulting from NextGen
ATC when the satellite signals that enable that reduced separation are suddenly
unusable due to solar activity? Presumably there's a reason the current
separation criteria have been used over the past decades and are currently,
because those separation criteria have proved to be safe. Therefore, it is
reasonable to expect less separation will be less safe if the enabling
satellite-based technology were to suddenly become inoperative while aircraft
are operating with reduced separation.
See what I mean?
On the other hand, the sun is quite a ways away, and from the information he
http://www.swpc.noaa.gov/phenomena/coronal-mass-ejections "fast CMEs can
reach Earth in as little as 14--17 hours" So, CME response on Earth isn't as
sudden as I imagined.
So how about:
2. ADS-B is dependent on the position reported the aircraft rather than
empirical evidence (radio energy reflected off of it: radar) of its position.
Under normal circumstances that's not an issue. But what of a hostile flight
bent on masking its position by transmitting misleading position information
for nefarious purposes? Without radar to confirm the position reported by
ADS-B, ATC becomes vulnerable to attack under NextGen ATC, where it hadn't been
previously (except under military ECM). How can that potential issue be
overcome?
My point is, that NextGen ATC has the potential to introduce more hazards into
the ATC system, and I haven't heard any of the entities involved in
advocating/implementing it address those hazards. That is worrying...
And the whole notion that the sky NEEDS to accommodate ever more flights may
not be valid, nor desirable from environmental and safety standpoints.
Thank you for your thoughtful input on this subject. I appreciate the
opportunity it provides to inspire me toward further research.
YOU can help stop the Australian camel killers , PLEASE tell all yourfriends to cancel all holidays in Australia and avoid the flies and diseases, or BYO face masks kangarooistan[_3_] Piloting 0 December 11th 09 05:52 AM
RAAF Signal - ''Cancel All Ops'' Dave Kearton[_3_] Aviation Photos 0 June 12th 09 01:39 AM
Historic Audio MP3 VH-XBA Boeing 707 Cancel Sarwatch TacAN Aviation Photos 2 June 11th 07 06:47 AM
Question cmsg cancel O%guh.803731$5R2.672463@pd7urf3no Ray S. & Nayda Katzaman Naval Aviation 1 February 7th 07 11:50 PM
Congressional move afoot to cancel FSS outsourcing contract with Lockheed R.L. Piloting 5 May 2nd 05 02:46 PM
