Getting out of the clouds in a Ventus C
Old May 9th 15, 03:50 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default Getting out of the clouds in a Ventus C
I promised to test one of the ideas for getting out of clouds alive (from the thread on Lucky Chuckar). This one involved gear down, full spoilers, full cross control, and manage speed with the elevator (by listening).
Results:
In the above configuration, the Ventus C has a strong and abrupt tendency to go into a steep dive with stick full back. closing the spoilers with controls still fully crossed results in a dramatic pull-up. I did not have the flaps extended for this experiment.
Conclusion:
maintaining a safe attitude and controlling speed in this configuration is impossible. It does result in a rather impressive rate of descent though....
I might try this again with spoilers fully closed one day, with fresh underwear...
Matt
Old May 9th 15, 05:56 AM posted to rec.aviation.soaring
Heinz Gehlhaar
Wow!!
Somebody please explain the aerodynamics for this.
The spoilers spoil the flow over the elevator when at extreme yaw?
Heinz
Results:
Conclusion:
Matt
Old May 9th 15, 06:15 AM posted to rec.aviation.soaring
Tango Whisky
Yes.
Bert TW
Ventus cM
Old May 10th 15, 04:44 PM posted to rec.aviation.soaring
Matt Herron Jr.
Test #2
Yesterday I tested a variant of the first test; Gear down, flaps to +2 (not landing flaps), spoilers NOT deployed, stick all the way back and left, rudder full right. I held the controls in this position without adjustment/input.
Results:
Plane went into an aggressive slip to the left, nose low. We did a slow, steady turn to the right for 2.5 revolutions. During that time pitch was stable. The nose came up a bit, then went down. the nose went down, but then came back up. Nothing dramatic. I think I lost about 1000ft/revolution. I will post the trace today.
Conclusion:
I personally would try this maneuver in clouds before bailing out. It seemed stable, with a high rate of decent. I don't know if I had elevator authority, as the stick was all the way back. I need to test the slip in the other direction to make sure the behavior is also stable (I tend to always drop the left wing on stall). Your milage will of course vary...
Anyone else want to try this?
Matt
Old May 10th 15, 05:26 PM posted to rec.aviation.soaring
Matt Herron Jr.
Update on test #2
Logger showed descent rate to be between 1500-2900 fpm. Turn rate was about 45 seconds per turn.
Matt
Old May 10th 15, 06:13 PM posted to rec.aviation.soaring
waremark
And if you try the more generally recommended approach of airbrakes out, hands and feet off? That seems to work in both the gliders I most often fly.
You should enter the recovery mode from an unusual attitude since you will probably be in an unusual attitude very soon after losing external visual reference.
Unless I have reason to think the cloud goes down to the ground, I would not consider bailing out unless/until the wings come off.
Old May 10th 15, 06:31 PM posted to rec.aviation.soaring
Richard[_9_]
On Sunday, May 10, 2015 at 9:26:20 AM UTC-7, Matt Herron Jr. wrote:
Update on test #2
Matt
Matt,
To be realistic and get a true sense of what will happen please do this with you eyes closed.
Richard
Old May 11th 15, 01:50 AM posted to rec.aviation.soaring
Matt Herron Jr.
You first, smart guy.
Old May 11th 15, 02:26 PM posted to rec.aviation.soaring
Richard[_9_]
Matt,
Seriously once you go into a cloud you will have no visual references. After about 30 seconds especially with the maneuver described you will have vertigo. What happens when you get out of the cloud? To establish your visual reference again may take another 30 seconds depending how serious the vertigo and what you do when you experience this. Things may get much worse. It is not just the aircraft that is the issue.
Richard
Old May 11th 15, 05:22 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Sunday, May 10, 2015 at 8:44:59 AM UTC-7, Matt Herron Jr. wrote:
Test #2
Results:
Plane went into an aggressive slip to the left, nose low. We did a slow, steady turn to the right for 2.5 revolutions. During that time pitch was stable. The nose came up a bit, then went down. the nose went down, but then came back up. Nothing dramatic. I think I lost about 1000ft/revolution.. I will post the trace today.
Conclusion:
Matt
I'd like to try full cross control vs full dive brakes with everything else the same.
Andy
Pyrocumulus clouds over CA son_of_flubber Soaring 0 August 7th 14 09:49 PM
Clouds bildan Soaring 9 December 20th 08 09:08 PM
PH-GRD breaking through the clouds Tom Hayden Aviation Photos 0 October 2nd 07 08:40 PM
How clouds are made Glenn[_2_] Aviation Photos 1 October 2nd 07 05:28 AM
