Saitek stick/throttle....rudder issue
Old November 16th 03, 04:06 AM
Default Saitek stick/throttle....rudder issue
Hey,
This is a pretty good stick/throttle combination, but it causes a quirky
behavior in that the aircraft rudder becomes very unstable on takeoff roll.
It slips from side to side, making takeoff a real challange. I'm pretty new
with this stick and would appreciate if anyone else having this problem
could give some feedback on it.
Old November 16th 03, 06:57 AM
Dashi
If you are trying to fly a single engine prop, that is the way it should
work. You need to keep a constant left rudder input during take-off and less
of an input in straight and level flight.
I've used the Saitek stick/throttle for a couple of years.
Dashi
"Wayne" wrote in message
Hey,
roll.
new
Old November 16th 03, 03:39 PM
I don't fly prop very often. Usually large commerical jets, (777, 747,
737-800)
So do I keep 'left rudder' on (the rudder toggle button on the underside of
the throttle control)
Thanks.
"Dashi" wrote in message
less
Dashi
Hey,
roll.
new
Old November 16th 03, 10:29 PM
Dashi
737-800)
of
Thanks.
Oops! I mean a right rudder input. The single engine prop aircraft will want
to turn to the left.
Using the rudder control on the Saitek is tedious, I use rudder pedals now.
Dashi
less
Dashi
Hey,
quirky
roll.
pretty
new
problem
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 04:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 09:58 PM
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! Bill Mulcahy General Aviation 3 October 1st 03 05:39 AM
