I'm running FS2004 and from the moment I start it up my cpu is running at
100% according to Task manager. My system is an Athlon 1.34 GHz cpu with 896meg RAM and a NVIDEA GeForce4MX440 with AGP8X.0 video card. I am running my monitor at 1280 X 1024 with 32 bit color selected. The result is scenery loss in the form of large blocks of scenery either missing or flashing on and off repeatedly. This for some reason only affects the scenery and not the panel. All FSIM settings are at default. Any help appreciated. |
"Murphy" wrote in message
news:zeaub.415810$pl3.146195@pd7tw3no... I'm running FS2004 and from the moment I start it up my cpu is running at 100% according to Task manager. Game applications using 100% CPU is pretty much par for the course. Even in situations where the video card is the frame rate bottleneck, games are usually written in a way that spends any time not dealing with graphics handling game mechanics and user input instead. If the game's not using 100% of the CPU, it's not trying. ![]() Your problems with the scenery graphics are likely related to something else. Maybe your graphics settings are too high, or maybe there's some sort of data or code corruption. Hard to say. Pete |
Yep, most games use 100% of the CPU and are the most demanding application
that can be run on a PC. You are running FS2004 at a high resolution for your video card. The MX series of Geforce cards are not really capable of heavy lifting at high screen resolutions. Try dropping your resolution to 800x600 and things should improve. If you have the cash, invest in a new Direct X 9 capable video card from ATI or Nvidia, one with 128 megs of ram. JK "Peter Duniho" wrote in message ... "Murphy" wrote in message news:zeaub.415810$pl3.146195@pd7tw3no... I'm running FS2004 and from the moment I start it up my cpu is running at 100% according to Task manager. Game applications using 100% CPU is pretty much par for the course. Even in situations where the video card is the frame rate bottleneck, games are usually written in a way that spends any time not dealing with graphics handling game mechanics and user input instead. If the game's not using 100% of the CPU, it's not trying. ![]() Your problems with the scenery graphics are likely related to something else. Maybe your graphics settings are too high, or maybe there's some sort of data or code corruption. Hard to say. Pete |
On Mon, 17 Nov 2003 12:45:09 -0800, "Peter Duniho"
wrote: "Murphy" wrote in message news:zeaub.415810$pl3.146195@pd7tw3no... I'm running FS2004 and from the moment I start it up my cpu is running at 100% according to Task manager. Game applications using 100% CPU is pretty much par for the course. Even in situations where the video card is the frame rate bottleneck, games are usually written in a way that spends any time not dealing with graphics handling game mechanics and user input instead. If the game's not using 100% of the CPU, it's not trying. ![]() Your problems with the scenery graphics are likely related to something else. Maybe your graphics settings are too high, or maybe there's some sort of data or code corruption. Hard to say. Probably either video or buss related. I run either CB FS, or 2004 AND the Seti at home project at the same time. It's not unusual to have other apps up at the same time although they end up in the background with reduced cycles. I haven't had any problems with the display freezing even with all the extra stuff, but the CPUs here run 100% just about 100% of the time, 24 X 7 as if nothing else is in the way the seti program will push it up to 98 to 100% along with the system apps. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Pete |
Thanks to everybody who took the time to respond.
Murphy "Roger Halstead" wrote in message ... On Mon, 17 Nov 2003 12:45:09 -0800, "Peter Duniho" wrote: "Murphy" wrote in message news:zeaub.415810$pl3.146195@pd7tw3no... I'm running FS2004 and from the moment I start it up my cpu is running at 100% according to Task manager. Game applications using 100% CPU is pretty much par for the course. Even in situations where the video card is the frame rate bottleneck, games are usually written in a way that spends any time not dealing with graphics handling game mechanics and user input instead. If the game's not using 100% of the CPU, it's not trying. ![]() Your problems with the scenery graphics are likely related to something else. Maybe your graphics settings are too high, or maybe there's some sort of data or code corruption. Hard to say. Probably either video or buss related. I run either CB FS, or 2004 AND the Seti at home project at the same time. It's not unusual to have other apps up at the same time although they end up in the background with reduced cycles. I haven't had any problems with the display freezing even with all the extra stuff, but the CPUs here run 100% just about 100% of the time, 24 X 7 as if nothing else is in the way the seti program will push it up to 98 to 100% along with the system apps. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Pete |
