Landing into a short field with obstacle on Final-The "window" method
Old May 11th 15, 04:31 PM posted to rec.aviation.soaring
Default Landing into a short field with obstacle on Final-The "window" method
I remember John Good (?) mentioning somewhere that when landing out he plans his pattern so that on final he passes through an imaginary window a bit above the final obstacle, at the right speed and aligned with the runway.
Wonder if someone has more information or can expand ?
Dan
Old May 11th 15, 05:10 PM posted to rec.aviation.soaring
Dan
The description sounds self explanatory to me.
UH
Old May 11th 15, 05:16 PM posted to rec.aviation.soaring
jfitch
Dan
The sill on the window isn't so imaginary...
Old May 11th 15, 05:54 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Dan
Dan take a look at https://www.youtube.com/watch?v=CXIm...8&spfreload=10 I think the most important thing is to always have an aim point, for every landing on your home field. This way when you land at another airport or field you will be able to spot land. Remember an obstacle on final will shorten your landing area by 8 times the height of the obstacle. For many pilots the aim point is the runway!
Old May 11th 15, 07:41 PM posted to rec.aviation.soaring
I thought your aim point should be the bottom sill of that "window" and than another aim point on the runway.
Dan
Old May 11th 15, 07:57 PM posted to rec.aviation.soaring
Tango Eight
That is an *excellent* presentation!
T8
Old May 14th 15, 03:02 PM posted to rec.aviation.soaring
Thank you Jonathan great video.
Dan
Dan
C-17 Short Final Sun n Fun - C-17 landing sun n fun 2010 (Custom).jpg Glen in Orlando Aviation Photos 0 April 22nd 10 09:57 PM
Short field landing Haiti Gulfside Instrument Flight Rules 0 February 24th 10 07:54 PM
Short field landing Lake Providence LA (0M8) with ATC COMS - Video A Lieberma[_2_] Owning 0 July 21st 09 01:06 AM
Sunday 072907 in Oshkosh Pt 1 - the C17 [6/6] - "20 C17 makes short field landing on roof of Marvel Manufacturing, later Marvel slices up C17 in retaliation.JPG" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 30th 07 11:49 PM
Now THIS is a short field landing John Harlow Piloting 8 March 16th 04 11:42 PM
