ARCHER III aircraft a mper ammeter
Old May 20th 15, 01:40 PM posted to rec.aviation.owning
Default ARCHER III aircraft a mper ammeter
Dears
I'm facing a problem in ARCHER III THE A MPER AMMETER fluctuate all the time
and even we change the alternator,voltage regulator and the master switch and
we check the wires continuity and the problem still existing
please advise
khalid khlouf
Old May 24th 15, 09:30 AM posted to rec.aviation.owning
On Wednesday, May 20, 2015 at 8:40:41 AM UTC-4, wrote:
Dears
please advise
khalid khlouf
I just fixed this problem on a piper warrior. Please THOROUGHLY check the field wire and B+ wire for chafing. We had a clamp that was juuuust loose enough to rub a very subtle hole in the insulation on our field wire, and it was causing it to periodically short to ground, just long enough to cause the regulator to full field, and then when it stopped shorting, the alternator voltage spiked briefly and would fluctuate the ammeter.
We changed out to a planepower alternator and regulator, and the regulator wouldn't tolerate the spikes, it would cut off completely for a few seconds before turning back on.
fluctuating ammeter, again texas slacker Owning 3 February 11th 07 05:27 PM
Ammeter, Shankland, a bit of help please RST Engineering Home Built 1 June 9th 06 02:40 AM
Volt / Ammeter ccwillwerth Home Built 21 February 22nd 06 01:49 AM
Volt/Ammeter ccwillwerth Home Built 0 January 19th 06 02:38 AM
Piper PA 12 Ammeter Jeff Restoration 0 November 18th 03 01:50 AM
