ASW-20 spins
Old June 3rd 15, 03:17 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
Default ASW-20 spins
Varies considerably with C of G position as well as from type to type. It
can also vary with mode of spin entry. The requirement, at the time of
Certification of the ASW20 in 1977, was "after a 5 turn spin, with the
aircraft in the most adverse configuration (normally this would be extended
aft C of G and usually positive flap in a flapped glider), the glider
should recover within 2 turns from intiation of recovery, which was,
central ailerons, full opposite rudder and stick progressivly forward until
the spinning stops. I did the UK testing for UK Certification of the ASW20
when it first arrived here. It came out in a little over 1 turn in the
worst configuration.
Some types may need full forward stick at aft C of G.
At 03:49 03 June 2015, Jonathan St. Cloud wrote:
I was just doing spins with a highly qualified instructor. My first two
spi=
ns, opposite rudder, neutral stick. I was told to move stick forward on
th=
e next three spins at same time as opposite rudder, recovery was faster
wit=
h less altitude loss, due to breaking the stall faster. I did not slam
the=
stick forward but I did for maybe a second move it forward. I have done
l=
ots of spins in gliders and powered planes, I think the stick position is
s=
omewhat glider specific. I have also soon a glider that would enter a
spin=
and immediately go to a spiral. The moral is get to know the spin
characte=
ristics of your glider
ASW-20 spins Jonathan St. Cloud Soaring 16 June 8th 15 08:30 AM
spins, c of a, & regs crashdummy Piloting 15 December 2nd 11 04:48 PM
Spins [email protected] Piloting 213 January 27th 08 12:37 AM
Any Spins Lately?? Ol Shy & Bashful Piloting 28 September 6th 07 10:22 PM
P=39's and flat spins. ArtKramr Military Aviation 10 July 15th 03 05:06 PM
