Near Vertical Takeoff
Old June 13th 15, 05:02 AM posted to rec.aviation.soaring
Roy Clark, \B6\
Default Near Vertical Takeoff
Skip the ad when you can to get to the video - looks like Grant County International Airport, near Moses Lake, Washington.
http://www.wsj.com/video/near-vertic...DBA8F2F54.html
Old June 13th 15, 10:22 AM posted to rec.aviation.soaring
Bruce Hoult
In reality, I believe it's around 50 degrees.
Old June 13th 15, 01:13 PM posted to rec.aviation.soaring
Not something you would see with passengers inside!
I would love to see a side view of that climb, I wonder how fast it's shedding speed?
Nice wing bend though. ;-)
Old June 13th 15, 05:05 PM posted to rec.aviation.soaring
Dan Marotta
From CNN: "Hero pilot saves the day."
From a passenger interviewed in the terminal: "We almost died!"
I can do that in my glider, though not for quite as long...
Dan Marotta
Old June 14th 15, 04:27 PM posted to rec.aviation.soaring
PBA
LOL @ DAn.
Awesome! Goes to show without all the ballast (human bodies) these planes have plenty of extra power.
Old June 14th 15, 05:59 PM posted to rec.aviation.soaring
Bruce Hoult
On Sunday, June 14, 2015 at 6:27:10 PM UTC+3, PBA wrote:
LOL @ DAn.
There's also the regulation that large twins have to be able to continue a takeoff from V1 [1] on a single engine at max all-up weight and the given runway length, wind, temp etc.
If you actually have twice that trust, as you usually do, it's jam.
I note that the A380 has an *extremely* leisurely climb out compared to the modern twins. It only has to have 33% more than the bare minimum power, compared to 100% more for twins.
[1] if an engine fails below V1 then you stop. If above V1 then you continue, but you must accelerate to at least V2 before actually lifting off.
Old June 14th 15, 07:38 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Yup - that's how they calculate Balanced Field Length. IIRC it's where the distance to get to V1 (takeoff decision speed), abort and stop equals the distance to continue the takeoff on one engine to 50' altitude. After V1 it takes more distance to stop than to continue on one engine.
9B
Old June 15th 15, 12:26 AM posted to rec.aviation.soaring
Dan Marotta
With all that extra thrust, we routinely set reduced power for takeoff.
We had a chart in the performance section of the flight manual for just
a thing. It considered runway length, density altitude, gross weight,
winds, etc. Should an engine fail, the remaining engine(s) would be
advanced to max power.
LOL @ DAn.
Dan Marotta
Old June 15th 15, 02:36 AM posted to rec.aviation.soaring
GM
Yes you can! Do a winch launch on one of those specially modified European winches that use over 11,000ft of line, hold that climb for 2 minutes and end up at over 4,500ft. I bet the jet cannot do that!
Uli
Old June 15th 15, 03:01 AM posted to rec.aviation.soaring
Dan Marotta
Wow!!! I'd love to try that!
Uli
Dan Marotta
vertical 1_0.jpg troy24 Aviation Photos 13 January 18th 11 01:54 PM
Vertical stabilizers Dallas Piloting 20 March 2nd 10 03:43 AM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Vertical and Short Takeoff / Landing Fighters Aviation Naval Aviation 7 January 5th 04 08:49 PM
Vertical and Short Takeoff / Landing Fighters Aviation Military Aviation 6 January 5th 04 01:18 PM
