Detergent for washing Fabric Aircraft
Old July 25th 15, 03:21 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Default Detergent for washing Fabric Aircraft
Any recommendations for washing the fabric on a Pawnee? I find myself sitting around the time of year twiddling my fingers waiting to fly a tow but rain, overcast.....you know the drill. I could be using my time to make our tow planes shine........your recommendations please?
I know about Simple Green for Aircraft but I understand that is for aircraft aluminum........
Walt Connelly
Old July 25th 15, 08:08 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Interesting note in the MD 500 POH they specifically prohibit the use of Simple Green due to it's corrosive nature. try a soaping mix of Dove and water.
Walt Connelly
Walt Connelly
Old July 25th 15, 08:27 PM posted to rec.aviation.soaring
Walt Connelly
Walt Connelly
Typically we just use an "Automotive soap" in water. There are tons of brands, some have "wax" in them to leave a bit of a shine.
IIRC, I tend to use a "Mcquires concentrated" (sp) for cars & aircraft. Just try to NOT do it in direct sunlight. A cloudy/rainy day is great.
Most "liquid dish soap" tends to strip any wax off the surface (not saying there is much to begin with....).
After dry, "Pledge" is a sorta cheap way to deal with a better surface, some of the "spray on, wipe off" helps cleaning after.
I REALLY shy away from the "miracle polishes" (Nu-finish, etc) since a lot have silicone in them, thus repairs/patches down the road don't stick well.
Old July 25th 15, 09:52 PM posted to rec.aviation.soaring
Darryl Ramm
"Charlie M. (UH & 002 owner/pilot)" wrote:
/snip/
If you are worried about silicon wax it makes no sense to spray with
Pledge, which is a silicone oil based spray.
Old July 26th 15, 01:41 AM posted to rec.aviation.soaring
/snip/
Not the last I saw, but there are always changes.
BTW, it's "silicone", not "silicon" (which is used in making PC chips, etc.)
I would have to go and look to see what Pledge is now, I may have to say, "I was incorrect in today's formulation".
I have no issue in learning new stuff.
Old July 26th 15, 03:57 AM posted to rec.aviation.soaring
Darryl Ramm
On Saturday, July 25, 2015 at 5:41:41 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
/snip/
Yes, obviously silicone, sorry iOS autocorrect got me.
And now I'm not on my iPhone.... here is a link to what is in Lemon Pledge. http://www.whatsinsidescjohnson.com/...mon-clean.aspx The silicone there is dimethicone aka polydimethylsiloxane aka "Silicone Oil" (https://en.wikipedia.org/wiki/Polydimethylsiloxane).
Pledge and similar sprays are something around 5-10% silicone oil, depending on product/dispenser type. That's what all the Pledge "no wax" and "no build-up" claims are about... it's silicone oil not a carnauba or petroleum wax based product that would build up. Being a woodworker it's the last thing I would ever get near any furniture I've finished (its harder to deal with silicone contamination with many wood finishes then automotive finishes, especially where silicon contamination is expected).
Many (Most?) of the spray plastic cleaners (spray bottles or aerosols) that folks use to clean canopies also contain silicone oil. Obviously that includes good old Lemon Pledge that many folks use, as well as specialized cleaners like Plexus Aircraft plastic Cleaner & Polish (my favorite). If you spray that stuff on your canopy you *are* coating nearby parts of your glider paint/gelcoat in silicone oil. I would use care to avoid getting it absolutely everywhere but hopefully any shop doing a finish repair or refinish will expect that/be able to deal with silicone contamination.
Old July 26th 15, 05:03 AM posted to rec.aviation.soaring
Daryl Hickman
I use Meguiare's Deep Crystal Car Wash on my Cubs...
Depression after Washing Charles Talleyrand Owning 69 July 13th 08 02:06 PM
Depression after Washing Charles Talleyrand Piloting 64 July 12th 08 02:13 PM
Dry Washing - Wing Waxers? Spitfire Owning 2 November 28th 06 01:28 AM
Washing a fiberglass airplane City Dweller Owning 5 May 22nd 06 02:13 AM
Washing - how often? Reid & Julie Baldwin Owning 15 May 7th 05 07:15 AM
