Buoyancy/Shear Ratio
Old August 1st 15, 03:55 PM posted to rec.aviation.soaring
Soartech
Default Buoyancy/Shear Ratio
What do you think about the BLIPMAP Buoyancy/Shear Ratio parameter?
Is it accurate that less than 7 makes the day difficult to work?
I have found lately that this seems to be true but my sample size
is small. I am in the northeast US. Location is probably a factor.
Old August 1st 15, 04:05 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
I had heard 5 was where it started to get tough. I have gone cross country on days with the forecast of 2. Not easy, but if cross country was easy, any monkey could do it! I would not pass on a day just because the forecast B/S ratio is low. I have had fairly smooth thermal climbs with winds of 35 to 40 MPH here in the midwest. I have also had very rough and broken climbs with winds less than 10 MPH.
Steve Leonard
Wichita, KS
Old August 1st 15, 04:12 PM posted to rec.aviation.soaring
Tony[_5_]
Usually accurate but like Steve I've had good thermals on days with very low B/S, like when I flew 525 miles in a 30-40mph tailwind
Old August 1st 15, 04:50 PM posted to rec.aviation.soaring
Tango Eight
The best thermals on any given day have better buoyancy, so better B/S ratio.
Days with a lot of shear put an absolute premium on thermal selection. I'd put the number where things start getting choppy at around 5.
-Evan Ludeman / T8
Old August 1st 15, 06:06 PM posted to rec.aviation.soaring
Papa3[_2_]
Agree with Evan and Steve above. A lot depends on your course selection as well. Crosswind legs on low B/S ratio day can be brutal. Upwind/downwind usually better. Also depends a lot on pilot thermaling ability. Low B/S days typically require "dynamic" thermalling (push/pull/stomp - whatever it takes to go up).
P3
-Evan Ludeman / T8
Old August 2nd 15, 07:22 AM posted to rec.aviation.soaring
Ramy[_2_]
Agree with all the comments above. In general windy blue days are more difficult. I normally don't check the B/S ratio as the BLtop, wind, cu potential and cu base (as well as convergence and total cloud cover) provide sufficient information.
Ramy
Rod ends in single shear Steve S. Home Built 11 September 30th 07 07:18 AM
Shear Pins for Propellors? Rich Lemert Piloting 25 April 3rd 05 09:04 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
