Aveo Gliderburst - Maximini
Old August 13th 15, 12:25 AM posted to rec.aviation.soaring
son_of_flubber
Default Aveo Gliderburst - Maximini
http://www.aveoengineering.com/gliderburst/
http://www.aveoengineering.com/redbaron-maximini/
Old August 13th 15, 12:45 AM posted to rec.aviation.soaring
Craig Funston
Will they double as wingtip skids ;-)
Craig
Old August 13th 15, 07:17 AM posted to rec.aviation.soaring
Bob Kuykendall
Once.
Old August 14th 15, 04:01 AM posted to rec.aviation.soaring
Dan Marotta
Those look pretty neat, but wouldn't the wires to power the lights duct
taped to the wing increase drag a bit? ;-)
Once.
Dan Marotta
Old August 16th 15, 05:41 PM posted to rec.aviation.soaring
duct taped to the wing increase drag a bit? ;-)
Once.
Dan Marotta
That's what they make hand-guided routers for, Dan! Run a groove under the wing and fill and sand with gel-coat after you're done. Nobody will ever know!
Old August 19th 15, 02:57 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
You are taking the wrong approach, Dan. Since power tools and your wings give you the shudders, let's take an approach that you are more comfortable with.
Using your .45, line the barrel up perpendicular to the root rib, parallel to the spar centerline. Fire. You now have a clear path root to tip inside the wing to route the wires. Stand wing on end, use fishing line and sinkers to place your "wire pull through cord" through the holes. This is the fun part where you get to be nearly 30 feet in the air to be able to lower the line and sinkers through the wing. Set wing back down on saw horses, and pull wires through wing. Note: Once the wires are in place, you will need to seal the ends of the ballast tanks in the LAK. If you had bought a ship with water bags instead of tanks, you could have skipped this step.
You will probably want to buy two sets of lights and install connectors so you can have the lights on either the 15 or 18 meter tips. I don't recall if the LAK 18 meter tips have a dihedral joint in them. If they do, it will require two shots from the .45 and a little duct tape near the corner.
:-) You are welcome.
Steve
Old August 19th 15, 03:44 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Steve! I just returned from the hardware store with a 40' ladder
and some studs for bracing the wings in a vertical position. I also had
to replace my hollow points with jacketed ball to keep the holes to a
reasonable size. I was able to do the 18 meter tips with the same shot
as the wings by carefully placing a steel deflector plate at the correct
angle inside the joint before connecting the tip. It took three tries
on the first wing (and a bit of epoxy and cotton flock), but the second
wing was accomplished with a single shot. The 15 meter tips were a
simple matter of using a long drill bit (of the proper diameter, of
course). :-D
Steve
Dan Marotta
Old August 19th 15, 08:41 PM posted to rec.aviation.soaring
Steve
All of you- get back to work!
LOL
UH
Old August 17th 15, 03:55 AM posted to rec.aviation.soaring
son_of_flubber
Maybe two of these http://www.aveoengineering.com/redbaron-maximini/ One on the turtle deck and one on the belly.
One of the wingtip lights installed on the nose or turtle deck and pointed forward towards head on traffic would be valuable. But would that be legal?
The Lxnav black box that turns on the strobe when it gets a Flarm alert is pretty sweet.
Aveo Ultra-H Batana Home Built 0 March 23rd 05 12:48 PM
