Open Bearing Question
Old August 24th 15, 01:44 AM posted to rec.aviation.soaring
JD Williams
Default Open Bearing Question
During my first annual with my Phoebus A1, we were looking at the rudder control arm connection and noticed an odd bearing. It's designed to move in multiple axes, so it seems like the bearings being exposed is notmal. But, having not seen such a beast, is there anything to pay more attention to with exposed bearings, different approach to lubrication, etc.
Picture of the connected assembly and the bearing:http://imgur.com/a/kbptW
Glider is a Phoebus A1 (1966)
Thanks!
JD
Old August 24th 15, 01:59 AM posted to rec.aviation.soaring
AS
Thanks!
JD
JD,
this is a common double row spherical ball bearing, designed to accommodate a good deal of misalignment. Typically, there is a felt ring on both sides keeping the dirt out and the grease in.
Wash it out with a good blast of brake parts cleaner, work some heavy grease into the space between the inner and outer race, install the felt rings and life will be good for a year or two.
Uli
'AS'
Old August 24th 15, 02:38 AM posted to rec.aviation.soaring
JD Williams
Thanks, Uli! I'll take care of that next weekend.
Rod end bearing for DG 200 aileron linkage JC Soaring 1 August 11th 10 03:14 PM
Need True Bearing [email protected] Simulators 1 July 5th 09 05:57 PM
Bearing and Course, differences? Allen Smith Piloting 27 September 2nd 07 03:28 PM
GO-300 Gearbox Bearing Source? Clay Owning 0 September 18th 05 02:46 PM
adjustable prop bearing Joe Home Built 5 October 23rd 04 12:00 PM
