Oudie DB9 pins to Powerflarm
Old August 25th 15, 12:28 AM posted to rec.aviation.soaring
Ken Sorenson
Default Oudie DB9 pins to Powerflarm
I have a PowerFlarm Core, an Oudie-2 running SeeYou Mobile, and an LX
Flarmview. I would like to use both the Flarmview and the Oudie as displays
for the Powerflarm. The RJ 45 connector on the PowerFlarm is occupied by the
Flarmview. I would like to connect the Oudie into the DB9 plug on the
PowerFlarm. I have the serial/power cable that came with the Oudie. It has a
configurable RJ45-DB9 adapter. Can someone tell me which color wire from the
RJ45 end of the adapter is inserted into which pin hole on the DB9 end of
the adapter.
Thanks, Ken Sorenson
Old August 25th 15, 01:23 AM posted to rec.aviation.soaring
Richard[_9_]
the adapter.
Ken,
The Oudie Power converter will plug directly into the PowerFlarm RJ45.
The easiest is to make or purchase a cable to go from DB9 to Flarmview.
$22
Richard
www.craggyaero.com
Old August 25th 15, 09:49 PM posted to rec.aviation.soaring
Paul Remde
Hi Ken,
I agree that your solution below is the best option. I show how to
configure the RJ45 to DB-9m adapter on my web site he
http://www.cumulus-soaring.com/seeyo...pter-RJ45-DB9m
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Ken Sorenson" wrote in message
the adapter.
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
Any news about PowerFLARM Brick or Bright Oudie availability? kirk.stant Soaring 4 April 15th 12 12:13 AM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
