Posting ealier about FS04 pc choice.
Got new PC and then it started to crash (2days old) Tech support says overheating......return for repair/replacement Really ticked me off, becasue FS was just gangbusters on the new PC. Rendering was really good and the controls were more realistic. Is a frame rate of 60-65 about what you would expect?? Funny thing though, I found that night landings were much easier with the new graphics. I guess if spend enough $$$, things should get better. This is my first pc with independant video/sound cards. Is overheating an issue with these new powerful 3D type cards?? |
Hi Ludlow,
This is my first pc with independant video/sound cards. Is overheating an issue with these new powerful 3D type cards?? Energy consumptions of modern high end cards is really high - as is the net amount of heat that must be lead away from the card. Overheating is a problem - after failure of the cooling devices or in systems which are generally designed 'on the edge'. I can't determine the cause for your problems being remote from the machine, but you generally do well buying non-discount PCs - their heat management is - generally speaking - a lot better whilst producing less noise emissions. Best regards, Peter |
On Thu, 12 Feb 2004 05:25:24 +0000, Ludlow Johnson wrote:
Posting ealier about FS04 pc choice. Got new PC and then it started to crash (2days old) Tech support says overheating......return for repair/replacement Really ticked me off, becasue FS was just gangbusters on the new PC. Rendering was really good and the controls were more realistic. Is a frame rate of 60-65 about what you would expect?? Funny thing though, I found that night landings were much easier with the new graphics. I guess if spend enough $$$, things should get better. This is my first pc with independant video/sound cards. Is overheating an issue with these new powerful 3D type cards?? I would suspect that the overheating was probably CPU related rather than video card related. Most all of the newer video cards have sufficient cooling solutions and decent PCs will have good ventilation. If you are getting 60-65fps, you might want to turn down the target frame rate and turn up the video goodies. Crank up the eye-candy and set your target at 25fps or so and you will see a lot more of what FS2004 has to offer. Ed |
"Ed Medlin" wrote in message news ![]() I would suspect that the overheating was probably CPU related rather than video card related. Most all of the newer video cards have sufficient cooling solutions and decent PCs will have good ventilation. If you are getting 60-65fps, you might want to turn down the target frame rate and turn up the video goodies. Crank up the eye-candy and set your target at 25fps or so and you will see a lot more of what FS2004 has to offer. Ed It might not be overheating at all. Could very well be an insufficient powersupply causing the crashing. When vid cards overheat you usually see some screen artifacts first. |
| Thread Tools | |
| Display Modes | |
| Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 5th 04 12:55 AM |
| AOPA VISA card fraud via XM Radio? | Dan Luke | Piloting | 5 | July 5th 04 07:38 PM |
| Video and Memory Card upgrade? | Dave Schwartz | Simulators | 3 | January 3rd 04 01:14 PM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
| Which Video Card? | Anthony Acri | Simulators | 1 | July 16th 03 04:12 AM |
