Bohli Compass
Old October 30th 15, 01:02 AM posted to rec.aviation.soaring
Default Bohli Compass
What is a reasonable value of a Bohli compass? does not appear to have ever been installed
Does it still have value?
r/Jim
Old October 30th 15, 06:09 PM posted to rec.aviation.soaring
Dan Marotta
No, it's worthless now. Please send it to me and I will dispose of it
properly. :-D
r/Jim
Dan, 5J
Old October 30th 15, 10:23 PM posted to rec.aviation.soaring
Stephen Damon
I hate to see Dan have to go to the trouble of opening the package so send it to me, collect!
Old October 30th 15, 10:41 PM posted to rec.aviation.soaring
Maybe I should put it on e-bay and see where it goes. Sounds like it is worth more than I thought.
Old October 31st 15, 02:16 PM posted to rec.aviation.soaring
Dan Marotta
I truly don't know what it's worth, if anything.
I've read that, properly set up, it can be used to fly in clouds. I've
also read that it was banned in contests in the US for just that
reason. It would be fun to have as a toy, just like that J-8 attitude
indicator that I've had in a box for close to 40 years.
Dan, 5J
Old October 31st 15, 07:04 PM posted to rec.aviation.soaring
krasw
lauantai 31. lokakuuta 2015 16.16.26 UTC+2 Dan Marotta kirjoitti:
I've read that, properly set up, it can be used to fly in clouds.*
I've also read that it was banned in contests in the US for just
that reason.* It would be fun to have as a toy, just like that J-8
attitude indicator that I've had in a box for close to 40 years.
I've flown with Bohli compass and it's main use is same as directional gyro's. When IMC (or VMC, of course) you can straighten your turn to correct heading right away if compass is tilted correctly. With normal Airpath compass procedure inside cloud is to straighten to any direction, wait 15-30 sec to get compass reading, then calculate how many seconds to make 30sec (or 1 min) standard rate turn to correct heading. This takes easily couple of minutes in all. These days any modern GPS gives you track reading at 1 hZ, which makes Bohli compass totally obsolete. You can not fly IMC with only Bohli compass, that has to be some misunderstanding.
Old October 31st 15, 03:09 AM posted to rec.aviation.soaring
AS
r/Jim
Weren't they once banned from use in contests?
Uli
Old October 31st 15, 05:07 AM posted to rec.aviation.soaring
Frank Whiteley
In continental Europe. Not sure if that expanded to the UK.
Old October 31st 15, 07:08 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
The ban was because a very skilled pilot could cloud fly without gyro
instruments, just using a Bohli compass. Not banned in the UK because we
allow cloud flying.
ever been installed
r/Jim
Uli
Old October 31st 15, 07:41 AM posted to rec.aviation.soaring
Ross[_3_]
r/Jim
Last one I saw sell on Ebay in Europe went for 165 Euro.
They are a valuable piece if in working order.
Wanted to buy Bohli compass Jonathan St. Cloud Soaring 3 April 28th 17 04:37 AM
Bohli compass operation Jonathan St. Cloud Soaring 6 August 31st 15 05:16 AM
Pictures of installed Bohli compass available? John Bojack[_2_] Soaring 1 August 12th 09 01:36 PM
Bohli Compass WANTED John Bojack[_2_] Soaring 1 June 12th 08 08:45 PM
FS Bohli compass Tom Stowers Soaring 0 October 24th 03 10:30 PM
