Foreflight
Old October 31st 15, 06:59 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Foreflight
Is anyone using Foreflight for soaring and if so what in particular do you like about this program?
Thanks
Old November 1st 15, 01:59 AM posted to rec.aviation.soaring
Default Foreflight
I've started using WingX Pro (http://www.hiltonsoftware.com) on my iPhone mostly as a replacement for sectional chart and to get the detailed airport info when needed.
If you are an current instructor, the software is FREE! CFIG only is good enough even though it's really an airplane tool. :-)
-Tom
On Saturday, October 31, 2015 at 11:59:41 AM UTC-7, Jonathan St. Cloud wrote:
Old November 1st 15, 02:39 AM posted to rec.aviation.soaring
Default Foreflight
It's excellent. Sectionals, frequencies & TFR's.
Old November 1st 15, 03:35 PM posted to rec.aviation.soaring
Dan Marotta
Default Foreflight
Don't know if Foreflight works on Androids or not, but Avare is free,
has current sectionals, IFR low and high charts, approach procedures,
TFRs, airport guide, flight planning..., etc. Created by a pilot for
pilots and you don't need anything special (licenses) other than an
Android device. Neither, do you need any kind of connection once you've
downloaded the data to your device.
Dan, 5J
Old November 3rd 15, 01:44 AM posted to rec.aviation.soaring
Andrew Ainslie
Default Foreflight
Coupled with a Stratus it'll save your life if you end up in accidental IFR.
Old November 4th 15, 09:56 PM posted to rec.aviation.soaring
Default Foreflight
I use stratus 2 and foreflight in our 170B. Luckily I haven't had to use the AHRS system in IMC conditions but it sure seems to be extremely accurate. I would like to see foreflight use the red, yellow, color scheme for obstacle and terrain clearance as does Garmin 430/496 does. way better to understand IMHO
CH
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
iPad + Foreflight Review Dane Spearing[_3_] Instrument Flight Rules 2 April 21st 11 05:17 AM
VFR Flight with more Ipad and Foreflight experiences - Video [email protected] Piloting 0 July 25th 10 05:21 PM
