fiberglass or carbon ? Need your help....
Old November 6th 15, 06:13 PM posted to rec.aviation.soaring
Dirk Darling
Default fiberglass or carbon ? Need your help....
I need your help identifying what material my mushroom panel is made of. It's from a DG-202. Given the age, I'm assuming it is painted fiberglass. But the black pigment runs deep - as if it is really carbon. I'm asking because I'm considering putting the GPS antenna puck under the panel. But if it is carbon, I need to mount it externally. I'm not sure if this is the stock mushroom panel.
https://www.flickr.com/photos/darlin...57660836834946
-ZP
Old November 6th 15, 06:36 PM posted to rec.aviation.soaring
Craig Funston
-ZP
The drilled holes for the speaker look like fiberglass as does the rest of the construction. You could put a multi-meter across the exposed fibers and check for continuity. Carbon is conductive and glass isn't.
Old November 6th 15, 06:54 PM posted to rec.aviation.soaring
The pod and panel are fiberglass with thick paint, and I have mounted antennas underneath with no obvious issues. But, I preferred to mount puck style antennas either on top of the pod, or on a bracket at the top front, well clear of the compass (if mounted on top), and run the cable through a hole in the front of the pod. Just because it is fiberglass and paint doesn't mean it would attenuate the signal to some (small) extent...
Marc (past owner of DG-101, 303, 600)
Old November 6th 15, 06:57 PM posted to rec.aviation.soaring
I need your help identifying what material my mushroom panel is made of.. It's from a DG-202. Given the age, I'm assuming it is painted fiberglass. But the black pigment runs deep - as if it is really carbon. I'm asking because I'm considering putting the GPS antenna puck under the panel. But if it is carbon, I need to mount it externally. I'm not sure if this is the stock mushroom panel.
"Would" should be "wouldn't"...
Old November 6th 15, 07:00 PM posted to rec.aviation.soaring
ND
-ZP
its definitely fiber glass. two reasons:
Carbon is more expensive and in a part like this which is non-structural, there is no benefit for incurring the extra cost for the unnecessary stiffness. also, if you zoom in on the pictures, you can see a little green (fiberglass/resin system) where the paint has worn, also the inside of all the drilled holes look white/green (fiberglass/resin system.)
Old November 6th 15, 07:08 PM posted to rec.aviation.soaring
Dirk Darling
Thanks guys! That is what I thought. I'll consider still mounting the antenna on the outside, but i wanted a cleaner look if attenuation isn't a problem - based on other posts on this site, it shouldn't.
-ZP
fiberglass repair? [email protected] Soaring 21 August 15th 15 01:55 PM
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
fiberglass tapes Lou Home Built 7 October 22nd 06 07:30 AM
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Aluminized fiberglass Dan, U.S. Air Force, retired Home Built 2 May 3rd 05 08:35 AM
