Holy UAT, Batman
Old January 1st 16, 10:11 PM posted to rec.aviation.soaring
Dan Marotta
Default Holy UAT, Batman
I just learned of this little gem: Open Source ADS-B In
http://www.eaa.org/en/eaa/aviation-communities-and-interests/homebuilt-aircraft-and-homebuilt-aircraft-kits/resources-for-while-youre-building/building-articles/instruments-and-avionics/live-weather-and-traffic-for-less-than-$120
For the money this looks like in interesting project for these gloomy
winter days. A second receiver (~$25) can be added for 1090ES.
Dan, 5J
Old January 1st 16, 11:08 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
gloomy winter days. A second receiver (~$25) can be added for
1090ES.
There have been a number of Raspberry Pi-based ADS-B In projects that can deliver ADS-B Out traffic as well as TIS-B (delivering ADS-B 1090ES, UAT and Mode C/S traffic for a 15 mile radius around you if you have ADS-B Out), plus FIS-B (including weather) AND any TIS-B traffic delivered to ADS-B Out-equipped traffic near you.
All for a lot under $100. With the right software you could deliver an NMEA stream to be MUXed with any other NMEA data you want to go do a display of your choice.
The really interesting detail from the EAA is that you might be able to receive all this information without equipping with ADS-B Out (though that may well be required for gliders post 2020.
Relevant excerpt:
"In most areas an ADS-B in signal can be had at or just above pattern altitude. You will begin receiving NEXRAD radar, METARs, TAFs, NOTAMs, TFRs, and other Flight Information Service - Broadcast (FIS-B) products. Some apps will explicitly note that these products are being received via ADS-B. With one radio tuner the unit will pick up traffic squawking ADS-B out on 978 MHz. If you are ADS-B out equipped, you will also receive TIS-B traffic. TIS-B is datalinked to FAA radar, meaning you get Mode C and primary targets. EAA is working with the FAA to expand TIS-B availability to all aircraft, not just those equipped with ADS-B out."
Pretty cool - you'll be able to see every aircraft for as far as you want to look - ultimately including most gliders I expect.
9B
Old January 1st 16, 11:24 PM posted to rec.aviation.soaring
Sarah[_2_]
It works well, and is pretty much a put-it-together-and it-works kit.
The drawback is any display requires an android or iOS app (foreflight), neither of which is especially handy in a glider cockpit. I used foreflight, and it showed weather & 1090es/UAT traffic if there was a ground station in line of sight.
The other problem is I found it to be noisy enough to break squelch on my glider radio(s), especially handhelds. A bit of experimenting with a shielded (metal foil?) case may fix that.
But I'm done playing. I have a Pi2, two SDR radios for dual UAT/1090es, a USB hub and miscellaneous cables. Anyone want to buy it off me? $75 including shipping. I never did get a 3d printed case.
The FLARM displays have much better ADSB 1090es displays - but of course require buying the FLARM core.
As far as traffic coverage - I would not rely on UAT TIS-b without an ADSB-out aircraft very near. Otherwise you won't see anything but 1090es ADSB.
"EAA is working with the FAA to expand TIS-B availability to all aircraft, not just those equipped with ADS-B out."
Don't hold your breath on that one. Selective broadcast is still the plan.
Sarah Anderson
On Friday, January 1, 2016 at 4:12:10 PM UTC-6, Dan Marotta wrote:
I just learned of this little gem:* Open
Source ADS-B In
gloomy winter days.* A second receiver (~$25) can be added for
1090ES.
Dan, 5J
Old January 1st 16, 11:34 PM posted to rec.aviation.soaring
Dan Marotta
Hi Sarah,
PM sent.
Dan
Sarah Anderson
Source ADS-B In
1090ES.
Dan, 5J
Dan, 5J
Old January 2nd 16, 12:06 AM posted to rec.aviation.soaring
Darryl Ramm
On Friday, January 1, 2016 at 3:24:05 PM UTC-8, Sarah wrote:
/snip/
Which means you really can't rely on it at all.
Exactly. Wishing is not having.
And has been discussed here recently, the FAA is actually tightening up requirements for ADS-B Out compliance.
The time for folks like AOPA and EAA to try to stop all this complexity and dual-link layer nonsense was really around a decade ago.
Darryl
Old January 2nd 16, 12:22 AM posted to rec.aviation.soaring
Darryl Ramm
And a reminder that PowerFLARM will not decode TIS-B (or ADS-R) so if that is your ADS-B receiver it does not help if you gave correctly configured/complain ADS-B Out or not. The popular hacker-Rasberry PI receivers do decode TIS-B.
Remember to see a TIS-B broadcast, the target/threat aircraft has to be transponder equipped and within coverage of SSR and it and you have to be within FAA ADS-B ground service coverage (and if playing on the ground you pretty much need line of site to a FAA ADS-B ground tower providing overage for that volume... so may not receive much TIS-B or ADS-R at all). And there has to be at least one "client" aircraft within 15nm and +/- 3,500' of the threat aircraft has to have ADS-B Out (UAT or 1090ES) and and advertising it has ADS-B In on UAT or 1090ES link-layer.. and hopefully for that aircraft it is advertising correctly what it really has) and the threat aircraft must not be transmitting ADS-B Out (or the ground system would just do nothing or use ADS-R, depending on what it thinks any ADS-B In client aircraft can receive...). Complexity like this is why we can't have pretty things that just work... :-)
Old January 2nd 16, 04:07 PM posted to rec.aviation.soaring
Dan Marotta
Yes, but part of something is better than all of nothing.
Sorry, couldn't resist that one. :-) Actually, Darryl, I very much
appreciate all you've posted on ADS-B. It's been very informative in
helping me make decisions for future operations. But, for me, this
software radio with DSP and output stream for various HW/SW products
already on the market looks like a great toy to while away the time
until spring makes more fun things realistic. And, if it actually
provides some traffic information, so much the better. I'll still be
looking outside. I think the realtime (neglecting unknown latency)
weather display will be fun to look at but, again, the view outside is
plenty sufficient for my kind of flying.
Dan, 5J
Old January 3rd 16, 01:45 AM posted to rec.aviation.soaring
Bill T
I built my ADS-B reciever using Rasberry Pi2+ and STRATUX software. Displays great on my iPad Air2 with ForeFlight.
Works great in the T-41B, a little crowded in the glider unless you're running on a phone.
BillT
Old January 3rd 16, 02:01 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
What would be cool would be if someone could have the traffic info stream out in NMEA instead of requiring Foreflight especially if it could output or the Raspberry Pi serial port so you could use a K6Mux to MUX the ADS-B UAT and TIS-B traffic into a normal glider display. Being able to overlay the FIS-B weather would be cool too. Yes I know that would require ADS-B out, but we may be required to do that in 2020 anyway.
How hard would that be?
9B
Old January 3rd 16, 02:23 AM posted to rec.aviation.soaring
Dave Leonard
9B
You don't need ADS-B out to get FIS-B weather. Just line of sight to a UAT tower.
The Stratux software running on a Pi2 emulates a Stratus receiver that provides the same functionality. The data is shipped out in garmin GDL90 format via a wifi connection which lots of different aviation software and hardware platforms can display. Including free software that could run on your smart phone.
They are adding GPS and AHRS functionality to the software if you want to add those sensors like Stratus has, too. Its all open source so feel free to change what you want.
holy smokes YouTube landing [email protected] Soaring 36 July 11th 07 08:18 PM
The Holy Shroud Acrux Piloting 3 September 29th 06 02:16 AM
Holy $#$ - eBay Copter Jimbob Home Built 37 September 13th 05 10:58 PM
Holy $#$ - eBay Copter Jimbob Piloting 23 September 13th 05 10:58 PM
