HELP fs2004/fs9
Old March 29th 04, 05:03 PM
Adam Jackson
Default HELP fs2004/fs9
On Mon, 29 Mar 2004 15:41:12 GMT, simpilottt wrote:
I really want to try to run flight simulator 2004 (already have x-plane).
I have two computers, but I need to know if the simulator will run
acceptably (20-30 frames per second) on the following systems. Thanks !
1. What's the result (quality) of using Microsoft Flight Simulator on an
Apple Powerbook G4 1 gz with 700+ram on OS 10.3.3 using Virtual PC?
I have no idea on this, although any emulated environment will be slow IMHO
- I'd be surprised if it ran at any acceptable speed...
2. How well does Microsoft Flight Simulator run on a Pentium III 500 mhz
PC with 128 ram?
I'd say you can pretty much forget running FS9 on this config. I have an
Athlon XP 2400+, overclocked to 2.2GHz, 1Gb RAM & a Geforce FX5900 & still
don't get 20-30fps *consistently* with details turned up high.
Please reply to this newsgroup, I cannot use my email address for non-
work related stuff.
Thanks
X-Plane just doesn't have the same levels of detail, so doesn't need such a
high-spec PC.
Adam
(Remove ".N*0*S*P*A*M" from email to reply!)...
Old March 29th 04, 11:00 PM
Angus Lepper
The apple will get maybe 10 fps with things set medium high when cruising,
dropping to 5 - 8 in busier places.
Angus
"Adam Jackson" wrote in message
x-plane).
IMHO
PC with 128 ram?
work related stuff.
Thanks
a
high-spec PC.
Adam
Old March 29th 04, 11:08 PM
John Doe
PC with 128 ram?
I get 20-30 frames per second on this (800x600, all sliders maxed but no
generated/fake scenery and no glare/lens/special effects, and default
weather settings).
....Athlon XP 2400+ (2 GHz) CPU
....512 MB, 133 MHz RAM
....GeForce3 video which is faster than low end GeForce4
Except in cities where it might fall to 15 FPS.
work related stuff.
Thanks
FS2004/FS9, Set location to non-airport? Squirrel Instrument Flight Rules 8 September 24th 04 12:43 AM
FS2004/FS9 and ATI Radeon 9800 Pro [email protected] Simulators 3 October 18th 03 07:07 PM
