Weather Updates/Reports Enroute?
Old April 6th 04, 09:27 PM
Chuck Dreier
Default Weather Updates/Reports Enroute?
In FS9, is there a way to check on current destination weather while enroute
while using the Real Weather feature? It would be nice to know what I'm
facing on arrival, have some knowledge on the runway likely to be used,
etc.. I know I could pull up a screen in the cockpit using FSMeteo, but I'm
not using that program any more. Is there a feature in FS9 that allows
this? Thanks!
Old April 7th 04, 04:28 AM
me @ comcast
unless you want to purchase "ActiveSky"
"Chuck Dreier" wrote in message
ink.net...
enroute
I'm
this? Thanks!
Old April 11th 04, 02:53 AM
David Wilson-Okamura
If your destination has an ATIS frequency, it will advise you of both the
current weather and the active runway. How do you find the ATIS frequency?
Use the "Nearest Airport" feature on the GPS or open the map (* button on
the dashboard) and click on the airport. Then tune to that frequency on one
of your COM radios. I usually use COM2 so that I don't miss ATC messages. If
you do it this way, be sure to select COM2 or select BOTH. This will let you
hear broadcasts on COM1 and COM2 simultaneously.
__________________________________________________ __________________________
ink.net...
enroute
I'm
this? Thanks!
making the transition from renter to owner part 2 (long) Journeyman Piloting 2 April 15th 04 10:19 PM
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
XMRadio Satellite Weather Has Arrived Richard Kaplan Piloting 37 September 2nd 03 02:51 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
