Yaw Damper
Old August 18th 04, 12:30 AM
Arthur Alspector
Default Yaw Damper
When should the 'yaw damper' be deployed in the Boeing 737 and 777? I
didn't notice the button in the 747. I have used it flying the Cessna 182S
and it works well to stablize the yaw in a crosswind, but I haven't figured
out if it's required in the large aircraft, especially when the autopilot is
engaged.
Thanks in Advance,
Arthur Alspector
Old August 20th 04, 08:29 PM
Johan Kütt
well, in a 737-500 checklist (for the dreamfleet cockpit) the yaw damper is
switched on in quite an early stage.
something like that:
(battery column from top to bottom) battery, some checks, ground power, bus
transfer, ...
(left column from top to bottom) ..., spoilers, ..., yaw damper, ....
I wrote it by memory so it might not be absolutely correct, but it should go
in a quite similar order. The YD isn't turned off until shutdown (don't know
about non-normal checklists).
johan
in article s.com, Arthur
Alspector at wrote on 18.08.2004 02:30:
engaged.
Thanks in Advance,
Arthur Alspector
A Q on horizontal turns Ramapriya Piloting 14 January 7th 05 11:46 PM
yaw damper for light twin Frank Ch. Eigler Piloting 5 December 18th 04 06:38 PM
B-52 Re-engining? MLenoch Military Aviation 150 October 6th 03 12:28 AM
