*Released 256 Command FA Voice Recognition Profile MSFS2004
Old December 20th 04, 03:06 AM
Sonar5
Default *Released 256 Command FA Voice Recognition Profile MSFS2004
Hi all,
I just uploaded to the library at Avsim a zip file titled:
fa172.zip
Get it he
http://library.avsim.net/esearch.php...til&DLID=58334
This package is only for use with the Flight Assistant program by Timm
Linder located library at Avsim or here.
http://www.linder-network.de/thelind...assistant.html
This Profile is by Joseph Ranos, (Sonar5) and includes 256 Voice
Commands that are all executed with a voice response.
Approximately 190+ Execute a MSFS2004 Key command as well as a Voice
response. (voice response may be limited if you do not have all
programs according to main Flight Assistant website). Approximately 60+
have a response but do not execute a key command. These are used for
Cabin Crew Calls, Jokes, and optimized with Cessna 172 Checklists to
show you the possibility of what the program is capable of.
(for use with Flight Assistant version 2.2 and Microsoft Flight
Simulator 2004 ONLY)
This package is uploaded to Avsim with the permission of Timm Linder,
the author of Flight Assistant, and it may NOT be uploaded to any other
site without the written permission of Joseph Ranos.
What is included in the Package:
1) fa172readme.pdf
This PDF file explains the use of the files, as well a stips before
changing anything in the file.
2) fa172.ini
This file is the BACKUP configuration file you will have when you
create the fa172 folder as advised below. It acts as a backup file in
case you delete the original.
3) FlightAssistant.ini
This file is an identical file to the fa172.ini above. This is what you
will use to replace the original .ini file that came with the program.
4) Fa172voicecommands.pdf
A separate PDF File showing all of the Voice Command prompts that can
be printed out for reference. These are in order of placement.
Subsequent versions will be cleaned up and organized, as I wanted to
get this out sooner rather than later.
5) fa172.txt a text file showing a limited amount of info.
Please Read the Readme PDF before you install it.
Regards,
Joe
Sonar5
Old December 20th 04, 06:25 AM
Sonar5
Correct Link to download Profile file is he Ignore the first one.
http://library.avsim.net/esearch.php...isc&DLID=58334
Regards,
Joe
Help with MC-1 & Voice Dave in San Diego Naval Aviation 5 August 24th 03 04:13 AM
