Better Boundary Layers
Old July 10th 03, 12:24 AM
Mike Borgelt
Default Better Boundary Layers
On Tue, 8 Jul 2003 17:08:46 -0700, Eric Greenwell
No, but Dick only tested one glider, and a very early one (early '94
production). Several changes have been made in the wing since then,
such as more blowholes, adding winglets, an additional flap position,
and using NACA ducts instead of pitot tubes. My experience flying my
ASH 26 E (built in early '95, retrofitted with NACA ducts and
winglets, and no profiling or sanding of the surfaces) against DG 800s
and Ventus 2 CMs is that all three have nearly indistinguishable
performance differences.
But the 26 is the only one with blow turbulators and it goes no better
than the two gliders without. I think you just made my point.
Old July 10th 03, 12:50 AM
Eric Greenwell
says...
I was answering your comment about the "terrible" ASH 26 polar. For
the blow turbulators, I previously tried to make the point that they
may indeed be the best choice for the airfoil that Schleicher chose.
The fact that it didn't give Schleicher a "definitive" advantage
doesn't mean this isn't true, as performance is affected by other
factors, such as the wing design (area, aspect ratio, winglets, etc),
fuselage and tail design, and so on.
Regardless of whether the ASH 26 would work just as well with zig-zag,
it is obvious to the pilot the blow turbulators are doing something!
Taping over just one NACA duct elicits an loud and eery chorus that
the Louek Boermanns, the airfoil designer, says is a vortex forming
behind the trailing edge of the wing. I can also hear the vortex in
wave conditions when the flaps are not set properly.
!Replace DECIMAL.POINT in my e-mail address with just a . to reply
directly
Eric Greenwell
Richland, WA (USA)
Old July 10th 03, 01:20 AM
John Morgan
"Mike Borgelt" wrote in message
So how's that prove BHs are ineffective? One could also say the 26e design
is somehow otherwise aerodynamically slightly inferior to the other gliders
mentioned. And that the BHs make up for this by bringing the 26's
performance up to par. Not saying I really buy this, but it makes about as
much sense.
I suspect blow turbulators provide a slight incremental improvement and
other manufactures don't think the gain justifies expense. Either way, it
doesn't much matter to me . . . they're on my 26e and they are way cool. To
those less fortunate "blowholeless pilots", I say, "tough"!
bumper
"Dare to be different . . . circle in sink."
to reply, the last half is right to left
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.495 / Virus Database: 294 - Release Date: 6/30/2003
Old July 10th 03, 02:57 AM
Mike Borgelt
On Thu, 10 Jul 2003 00:20:05 GMT, "John Morgan"
much sense.
That is about what I said. Nobody can point to a definitive real world
advantage held by any production glider with blow hole turbulators.
Hence blow turbulators have not become universal.
Old July 10th 03, 04:23 PM
Jose M. Alvarez
Yeah but sure they're cool when showing your new glider to your friends...
I prefer old fashioned zigzag tape. Easier to mantain and clean.
Good flights
Jose M. Alvarez
ASW24
"Mike Borgelt" escribió en el mensaje
Old July 10th 03, 02:37 AM
Udo Rumpf
In the case of the 26 and 27 one must not narrow it down to just the
blow holes. Aside from the structural features, the gliders have
incorporated truly aerodynamic advances. For the gliders to
perform as they do everything had to work just right. Consider the
fact it has the smallest wing area of the " three" the Diana is even
smaller. It has the highest dry wing loading of any 15meter class glider.
Still it is able to soar with the lightest in its class, with only the
slightest
disadvantage. As soon as the wingloading goes up, when conditions
allow, this glider is in a class by it self.
At the time I thought Waible should have gone about it incrementally,
rather then design a radical new glider for production.
Look at the fuselage shape only, it required a new wing/fuselage juncture.
The others still use the wing straight into the fuselage.
The airfoil had to generate more lift due to smaller wing area as well make
it thinner to reduce drag. A small gain could be realized with the higher
aspect ratio that came with this wing lay out. Waibel was the man that
knew/felt
laminar flow could be obtained past 90% of chord across a hinge line. He
pursued that goal with the help from Loek Boermans.
Also the wing fuselage intersection was L. Boermans doing.
The blow holes are not an insignificant part in making the glider what it
is.
If it could just shed 75lb of its empty weight and we would not have this
discussion about blow holes.
Regards
Udo
Old July 10th 03, 02:48 AM
Greg Arnold
The Idafleig tests show that the '27 polar is in a class of its own, and
significantly better than the Ventus 2. See page 168 of Fundamentals of
Sailplane Design by Fred Thomas.
"Udo Rumpf" wrote in message
slightest
make
knew/felt
is.
Regards
Udo
Strange Class D boundary??? Roy Smith General Aviation 2 August 30th 04 01:56 PM
F104- Boundary Layer Control Scet Military Aviation 7 August 27th 04 09:48 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
