Fitting canopy frame to fuselage advice
Old July 22nd 03, 03:16 AM
Deputy Dog
Default Fitting canopy frame to fuselage advice
My Discus2 canopy and frame fit a little too tight to the fuselage
making closing difficult or impossible when it really heats up. In
the winter it was much better, but still a bit tight. At normal
temps. in Florida (90 to 95 degrees this time of year) in the shade,
it is clearly too tight, since even when closed the frame is not flush
with the fuselage and it takes a good deal of force to close it which
can't be good for it.
I've tried waxing both interfaces, and it is better, but still not
flush. It seems that a light sanding is in order where contact is
made.
Any good advise on what grade of paper to start with and a progress of
grits and whether the sanding should be done on the frame or fuselage,
or some on both.
Any good advise is appreciated.
Thanks-
Deputy Dog
Who can identify this tube frame aircraft fuselage? Rob de Bie Home Built 5 January 13th 05 10:45 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 04:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
