GPS and DME
Old February 14th 05, 07:10 PM
nobody
Default GPS and DME
Does anyone know if it is legal to substitute distance and speed from an
approach certified GPS in place of a DME on a DME required approach?
Ed
Old February 14th 05, 08:50 PM
Jim Burns
Yep. See rec.aviation.ifr, we've pretty much beat it to death. Also see
the AIM.
"nobody" wrote in message
m...
Ed
Old February 15th 05, 12:15 AM
Ron Rosenfeld
Probably. What is the approach in question?
Old February 15th 05, 05:30 AM
nobody
No specific approach. I want to upgrade my panel and debating spending less
on a new GPS so I can install DME too or spend a little more on a nicer GPS
and blow off the DME.
I read the threads on rec.aviation.ifr. There was truly a ton of info
there.
Ed
"Ron Rosenfeld" wrote in message
Old February 15th 05, 11:55 AM
Denny
The bottom line is simple... GPS is a legal substitute where the GPS
distance measurement matches the DME numbers... It is not legal where
the DME is offset from the VOR or airport center and the GPS database
does not correct for this... Increasingly, the DME location and/or the
GPS databases have been matched up so either the GPS or the DME gives
you the appropriate distance measurement, and offset DME's are now
definitely in the minority...
You can skip installing the DME and simply check your approach plates
to be sure you are legal (and out of the trees) when shooting a DME
approach with the GPS as your distance measuring equipment...
There is the occasional approach that I run into where the plate says
DME REQUIRED... If you are IMC then you will simply have to shoot a
different approach using your GPS... OTOH, if the fickle finger of
fate takes down your GPS (for whatever reason) you may be wishing you
had a DME on the panel... I have both GPS and DME on board and both are
in use as cross check when shooting approaches...
Denny
Old February 15th 05, 03:58 PM
Newps
Not quite right. GPS can substitute for DME even when the DME source
isn't in the database. For example my terminal/enroute GPS does not
have the DME location for ILS's. One of the approaches here at BIL
requires DME. I simply make the OM the active waypoint.
Wrong. If you can determine distance with your GPS then you are good to go.
Old February 15th 05, 05:55 PM
Denny
Hmm, not to be difficult, but if you come to the attention of the FAA
after shooting an approach using a GPS where the plate says DME
REQUIRED and the FSDO gets involved, it will be very entertaining to
listen to you lecture the inspector that you can simply create your own
approaches... But, you fly your ship your way and I will fly mine and
we will both be happy...
Cheers ... Denny
Old February 17th 05, 01:08 AM
Newps:
Why use the OM as waypoint? The DME at BIL is at the VOR, isn't it??!!
Which approach are you referring to, the ILS 28R or VOR_DME 28R?
Old February 15th 05, 01:09 PM
Ron Rosenfeld
I recently installed a CNX80 (now GNS480) and got rid of my DME. I've not
run into any circumstances where I miss it.
Old February 15th 05, 01:53 PM
Jim Burns
Glad you caught the threads in rai. I was in no way trying to blow you off
or dismiss your question, it was just very timely. Be sure to check out the
AIM also http://www.faa.gov/ATpubs/AIM/Chap1/aim0101.html#1-1-19 see
section (f).
om...
less
GPS
there.
Ed
