Dashing downwind
Old February 25th 16, 04:35 PM posted to rec.aviation.soaring
Tony[_5_]
Default Dashing downwind
Making a run southeast from Sunflower in Kansas. Hoping to launch at 11 central. Follow on SSA Tracker or glideport.aero
Old February 25th 16, 05:04 PM posted to rec.aviation.soaring
JS
SGS. Spring Go South!
Have fun, we'll be watching later on.
Old February 25th 16, 07:38 PM posted to rec.aviation.soaring
Chris Snyder
Newbie question: Downwind? Is this a one-way trip to maximize ground covered?
Old February 25th 16, 08:06 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Yes. He's flying to maximize distance. He did a 750 km Diplome flight a year or two ago this way ( see write-up at http://soaringcafe.com/2014/03/spring-go-south/ ; actually 844 km ). At 2:50 Eastern time, he's already past 300 km. He's working a band 5-6000, occasionally to 6500' (you see this on the tracker at glideport.aero - the "K" tracker, not "YYY"). About 70 mph/112 kph achieved spped so far - which is very good... probably the Cirrus (first flight in March 1969; very nice, but not state of the art now). Best L/D of 36:1.
Now over 325 km in 2 hrs 53 mins; excellent! Looks like a cross-wind, then turning east for a tailwind at the end of the flight ( https://www.windyty..com/?850h,2016-....952,-89.187,6 ). Select 5,000' for the wind he's in. You can also see some clouds up ahead (but there are ridges down there to run).
Always on a weekday...
Go Tony!
Old February 25th 16, 08:12 PM posted to rec.aviation.soaring
Yes, that's right. In the "ooooold" days when the hot ship was the 1-23 or K-6
it was the way to get the Gold Distance. Nowadays with higher performance
ships it can be a way to generate a multi-day retrieve!
Matt
Old February 25th 16, 08:38 PM posted to rec.aviation.soaring
BobW
covered?
http://soaringcafe.com/2014/03/spring-go-south/ ; actually 844 km ). Snip...
Chris,
You'll better understand the allure of what's nowadays often,
generally-fondly, referred to as "a vulgar downwind dash" once you've a bit
more experience under your belt...say, when you begin seriously considering
flying your Silver Distance badge leg in your club's 1-26! Based on last year,
Tony's probably trying for a seashore landing this year, or maybe the Caymans.
All levity aside, many (most?) soaring pilots will admit to - at one time or
another - seriously daydreaming of simply attempting to soar as far in a
single (meaning, downwind) direction as a decent day will allow. It's a
"freedom of flight" thing harking back to the early days of the sport of
soaring when the whole idea of powerless flight was new, and penetrating into
the wind was more a concept than a reasonable possibility, given the ships of
the day. See anything written by Philip Wills...
In U.S. latitudes, unstable air trailing springly cold fronts combined with
typically strong northerly winds behind the front, make for Real Temptation,
depending upon one's starting geographical location. Tony doesn't merely dream
about it, though!
Bob W.
Old February 25th 16, 09:53 PM posted to rec.aviation.soaring
WB
Now over 325 km in 2 hrs 53 mins; excellent! Looks like a cross-wind, then turning east for a tailwind at the end of the flight ( https://www.windyty.com/?850h,2016-0....952,-89.187,6 ). Select 5,000' for the wind he's in. You can also see some clouds up ahead (but there are ridges down there to run).
Go Tony!
Hmm, the wind has him coming straight towards me. Maybe I need to get the guest bedroom ready...
Old February 25th 16, 10:25 PM posted to rec.aviation.soaring
Tony[_5_]
Made it to declared goal of Talihina, OK with not much trouble. Spent a little more time below 5500 msl than I'd have liked in the last 40 miles there.
Got back up to.cloudbase at Talihina. Wind had turned a bit westerly aloft and i wasnt sure about the velocity on the ground so I didn't drop down to the ridges.
Decided to head crosswind to Mena. Nice airport. FBO, and HEAT. My toes are cold!!
Still some nice cu up there but I could see the southern end of the cu field. Did I mention.my toes were cold.
Diamond Distance in February! Woot!
Old February 25th 16, 10:47 PM posted to rec.aviation.soaring
Tony[_5_]
http://www.onlinecontest.org/olc-2.0...htId=446477652
Old February 25th 16, 10:54 PM posted to rec.aviation.soaring
Dan Daly[_2_]
"If your feet are cold, wear a bigger hat".
Nice flight, Tony. Beats watching it snow...
Dan
More Downwind Dashing Tony[_5_] Soaring 5 April 25th 14 07:49 PM
F-16s on the downwind leg [3/3] - DSC_3034.jpg (1/1) Indrek Aviation Photos 0 December 16th 10 09:30 PM
F-16s on the downwind leg [2/3] - DSC_3029.jpg (1/1) Indrek Aviation Photos 0 December 16th 10 09:30 PM
Follow up Alright, All You Dashing, Swaggering Bush Pilots wmbjk Home Built 135 September 8th 03 06:09 AM
Alright, All You Dashing, Swaggering Bush Pilots Larry Smith Home Built 22 August 14th 03 10:03 PM
