Blanik screws?
Old March 25th 16, 01:33 PM posted to rec.aviation.soaring
Wade G
Default Blanik screws?
I'm looking for a few replacement screws for access panels on my Blanik L33 Solo. The screws are M4x14 hex heads. The odd part: They are a very low oval head and the countersink taper is about 120 degrees. They are much like countersunk rivets (same angle).
I have been quoted by the factory with a lofty price....$21.40 EACH!
Does anyone know if a source for these in the US? I am not sure if these have a specific DIN #.
Thanks, Wade
Old March 25th 16, 03:52 PM posted to rec.aviation.soaring
Check mcmaster.com
Oval head may be what you're looking for
Old March 25th 16, 04:00 PM posted to rec.aviation.soaring
Wade G
Been there already. The common oval head available is only in the 90 degree range. I'm wondering if any L-29 or L-39 folks know what I'm referencing since LET Aircraft built Blanik's and L-29s.
Old March 25th 16, 04:09 PM posted to rec.aviation.soaring
Bob Kuykendall
Buy the McMaster screws, have a local machinist recut the head to the required angle.
Old March 25th 16, 04:31 PM posted to rec.aviation.soaring
Craig Funston
Is the same screw used anywhere in the L-13? If so, there are hundreds of them out there waiting to be useful.
Old March 25th 16, 05:52 PM posted to rec.aviation.soaring
George Haeh
I passed on your email to a buddy who
bought a written off L-33.
Old March 26th 16, 03:06 PM posted to rec.aviation.soaring
Oscar-Hotel-Mike
I imagine that Blanik America will have what you need. I have used them several times and nearly always have what I need in stock, nuts, bolts, bearings, etc. http://home.nwi.net/~blanikam/ba/home.htm
Old March 26th 16, 04:00 PM posted to rec.aviation.soaring
Bob Kuykendall
Yes, at $21 per screw, as stated earlier in this thread.
Thanks, Bob K.
Old March 26th 16, 04:03 PM posted to rec.aviation.soaring
Bob Kuykendall
Thanks, Wade
I try to make five or ten of these for you today. I'll get some SS M4x15 90-degree screws and undercut the heads to 110-deg so they'd work OK for either 100 or 120 holes.
Thanks, Bob K.
Old March 27th 16, 04:00 PM posted to rec.aviation.soaring
Wade G
Ultimately what I likely will do is dimple to 90 degrees so for the non structural spots, I can use the ones at ACE hardware's "AN" section...
I think the high cost from Blanik is because the screws are not made anymore. That might have been the cost to have them manufactured again.
Blanik L -23 canopy screws John Brennan[_2_] Soaring 3 May 19th 11 02:49 AM
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
TR-21 mounting screws [email protected] Soaring 10 March 26th 10 12:14 AM
FAA Screws Up Again BushOKDemocratsSTUPID Instrument Flight Rules 2 March 22nd 06 10:39 PM
Avsim screws itself Azhosers Simulators 2 April 5th 04 10:32 PM
