possible low-cost solution to satisfying ADS-B requirement in gliders
Old April 7th 16, 02:20 PM posted to rec.aviation.soaring
Bob Pasker
Default possible low-cost solution to satisfying ADS-B requirement in gliders
perhaps the SSA can learn from the EAA about how to get an STC for experimental equipment to satisfy the ADS-B requirement
http://www.eaa.org/en/eaa/eaa-news-a...04-06-2016-stc
"EAA, FAA, and Dynon officials said they have established a supplemental type certificate (STC) process for installation of the Dynon EFIS-D10A as a replacement for the airplane's primary attitude indicator. This allows innovations developed for the amateur-built aircraft fleet to make their way into specific Cessna and Piper models."
--bob
Old April 8th 16, 10:31 PM posted to rec.aviation.soaring
Bill T
Not to cause confusion, but there is currently no requirement in the U.S. for ADS-B in gliders, no transponder either.
BillT
Old April 10th 16, 04:13 AM posted to rec.aviation.soaring
2G
BillT
Unless you want to enter class A, B, or C airspace. It will also make you visible to other traffic. I installed a transponder after having a close encounter with a 737 near Reno.
Tom
Requirement of AW 139 pilot sanjay Rotorcraft 2 August 25th 08 10:06 AM
FAA's Proposed ADS-B Requirement May Cost Aircraft Owners $9K. Comment Period Extended Larry Dighera Piloting 4 December 4th 07 04:31 PM
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Question about cost of Gliders Sruti Raju Soaring 2 June 26th 05 09:26 PM
New Castle ELT Requirement Ed Byars Soaring 16 June 19th 04 06:15 PM
