GPS format for spot
Old April 8th 16, 12:34 AM posted to rec.aviation.soaring
Blake Seese 3Y
Default GPS format for spot
A couple years ago, I landed out at a contest and my retrieve took quite a while because the driver could not find me even though my position was known. It turned out that the contest person in charge of retrievals had one format in her locating program, and the output from the spot was in decimal. This caused the retrieve to look for me in slightly the wrong place. My question is, which format should be used, and is there a setting on the spot page where the output format can be changed.
3Y
Old April 8th 16, 03:02 AM posted to rec.aviation.soaring
Bill T
I don't think SPOT can be changed. The person in charge of retrieve desks need to be properly schooled in converting degrees.decimaldegrees to degrees, minutes.decimalminutes and charting same.
BillT
Old April 8th 16, 09:13 AM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
BillT
Surely that is the Retrieve Crew's responsibility.
Old April 12th 16, 01:08 AM posted to rec.aviation.soaring
2G
On Thursday, April 7, 2016 at 4:34:11 PM UTC-7, Blake Seese 3Y wrote:
A couple years ago, I landed out at a contest and my retrieve took quite a while because the driver could not find me even though my position was known. It turned out that the contest person in charge of retrievals had one format in her locating program, and the output from the spot was in decimal.. This caused the retrieve to look for me in slightly the wrong place. My question is, which format should be used, and is there a setting on the spot page where the output format can be changed.
3Y
Both formats (decimal degrees and hours, minutes & seconds) are used by various devices. People need to know how to convert between the two. At a contest the retrieve desk should give the retrieve crew the location in BOTH formats.
BTW,
Convert hours, minutes to fractional degrees:
fractional_degrees = hours / 60 + minutes / 3600
Convert fractional degrees to hours, minutes:
hours = integer part of [fractional_degrees * 60]
minutes = integer part of [(fractional_degrees - hours/60) * 3600]
seconds = (fractional_degrees - hours/60 - minutes/3600) * 216000
Old April 12th 16, 02:57 AM posted to rec.aviation.soaring
3Y
BTW,
There has to be apps for cell phones that can do this easily.
What apps for this are preferred? Who recommends what?
Old April 12th 16, 03:47 AM posted to rec.aviation.soaring
Giaco
3Y
BTW,
I would just put the coordinates into google maps and the that app direct me there on the shortest route, while adjusting for traffic... no need to worry about conversions!
Old April 13th 16, 03:48 AM posted to rec.aviation.soaring
2G
A couple years ago, I landed out at a contest and my retrieve took quite a while because the driver could not find me even though my position was known. It turned out that the contest person in charge of retrievals had one format in her locating program, and the output from the spot was in decimal. This caused the retrieve to look for me in slightly the wrong place.. My question is, which format should be used, and is there a setting on the spot page where the output format can be changed.
3Y
BTW,
Yeah, I did that once. The route directed us over a very rough "road" that had washouts. The first one we crossed by pulling the trailer across suspended by the tongue and rear end; the second one was too deep to consider. Had to back-track and find an alternate route. I had to do this conversion to compare our location from a Tom-Tom GPS to a set of maps we had.
Old April 13th 16, 06:49 PM posted to rec.aviation.soaring
3Y
BTW,
Ah, yes, I forgot to send my girlfriend to the contest desk for coordinates last time I landed out...
Or, I'll just send that conversion info then to my girlfriend with a Psychology degree, let me cut and paste that into an email to her right now. Then I'll fly off into the great unknown this summer, particularly the majority of areas with great soaring and no cell coverage in the western US, with absolute confidence that she will show up stat with trailer in tow. Remember, this is a case where spot was the only form of communication, it's main function...
Or you could get a navigaton GPS and set the coordinate input format to the format that your Spot outputs. Voila, enter the numbers exatly as seen from the spot info.
Sorry 2G, just poking fun, lots of different retrieve scenarios out there....
Old April 19th 16, 02:53 AM posted to rec.aviation.soaring
2G
3Y
BTW,
Better to think about it now rather than in a field somewhere that you just spent the night...
Spot vs Spot Connect guy Soaring 9 January 25th 12 03:48 PM
Format display Delbert Soaring 1 May 18th 09 01:41 AM
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
New 'Soaring' Mag Format Paul Hanson Soaring 0 February 3rd 08 12:19 AM
New fun racing format Kirk Stant Soaring 1 October 8th 03 06:46 AM
